Reverse2057
Everything posted by Reverse2057
  1. @Dwight @CaptQuirk @dirkba @TinkerTailor So I promised to show you all the finished product when it was done! The pop rivets were a brilliant idea and one I went with. Drilling the bullets without a drill press was way hard, but I had some helping hands thankfully. Was able to buy an entire hide of deeply oiled leather that's normally like $160 for only $80 today, so I jumped on the project and finished it up. Cut everything myself for the band, punched the holes, affixed it all m'self as well. I'm super pleased with the results for it being my first time ever doing something of this nature, so thanks for all your help guys! :D! Enjoy!!! http://imgur.com/a/1YtfD
  2. Oh I will! If it turns out as I hope I'll be wanting to show it off for sure. Great advice! I'll have extra bullets in case I screw up on some of them and likely extra leather in case that somehow gets messed up as well. I'll likely do a practice attempt on some scrap leather and an extra bullet so I can get the finished product looking good without making a mistake. But I'm glad you pointed out that the bullet wall will be fragile and something to be wary of warping, that hadn't crossed my mind yet!
  3. Oh! Looking up a video on a pop rivet i think that actually might do the trick! Thank you guys so much for the help!
  4. Ah nice idea! My only qualm is there will be a rivet showing on the front of the bullet won't there? I'm trying to avoid showing anything on the front of the bullet if possible. But if there's no other way I can find that might be my best option.
  5. Hey all, New member here, but I'm running out of places I can search for help on either ideas or instruction. I have a hat band I'm wanting to make, and I haven't yet gotten all the supplies because I'm not sure what all I'll need for the project. My goal is to make a leather hat band with unobstructed bullets around the outside. I'm wanting to avoid the typical bullet loops look or stitching around the front of the bullet, as I feel it would obscure the bullet itself aesthetically. I'm going to be using pre-fired .357 Magnum brass bullets and leather for the hat band itself. I have a hat band currently on my hat, and the decorative pieces on it have a type of diamond-shaped rivet with prongs that punched through the band to be bent back to secure them on sort of like a staple. Simple stuff. The bullets I'm getting can have a hole drilled into them, and in my mind's eye I pictured something like some sort of brad or rivet securing inside the drilled hole of the bullet, so essentially the bullet would have prongs sticking out of it on one side that I can then use to secure it to a hat band cleanly. I hope that made sense. A friend suggested some sort of contact cement or glue or goop but I worry that a bullet's surface area onto leather would prove both too small and weak in lasting under duress of wear and tear, and would be messy and not clean in presentation if I were to go this route. tl;dr: I'm searching for help on if there's a way to give the bullet some sort of prongs that can be put through a leather hat band while looking slick and put together and not sloppy. Would there be a way to simply secure the rounded surface area of the bullet to a flat rivet itself which then can be secured to the hat band? Is it even possible to drill a hole into a bullet and have something inserted that would create prongs for the bullet itself? Are prongs even the best way to go about this? or would glue or goop or contact cement prove better? The leather hat band will be sitting snug against a high-quality leather cowboy hat so I also want it to be safe against the leather of my hat without scratching or something. I'm completely new at all of this so any and all ideas and help would be greatly appreciated! Thanks for your time!
