westcoasters
  • Content Count
    7
Everything posted by westcoasters
  1. Hey everyone, apologies for dropping the ball on pictures. Recently had knee surgery. I have a few more machines for sale and will make a new thread as soon as the pictures are resized. Here are the four machines currently listed. Juki DDL-550-6 Consew 369 RB1 Juki LBH-182 Juki LU 562
  2. JUKI LU-562 Single needle, unison feed, lockstitch industrial sewing machine Reverse feed Sewing speed - up to 3,000spm Presser foot lifting range - 15mm (19/32”) Max feed range - 7mm (9/32’’) Ideal for heavy weight fabrics Needle Type - DP x 17 (135x17) Needle size - #18 - #23 Thread size - up to 138 $900 w table/motor Refurbished/ As Is _________________ JUKI LBH-782 High Speed Single Needle Lockstitch Straight Button Holing Sewing Machine Buttonholes for ordinary cloth, knit, leather ect. Buttonhole length - 6.4-25.4mm (¼’’-1’’) Bartack width - 2.5 - 5.0mm (3/32’’ - 3/16’’) Needle Type - DPx5 Needle size - #11-#14 Presser lift - 12mm (15/32’’) $1400 - refurbished/ as is ________________________ Juki DDL-5550-6 Single needle, lockstitch, walking foot sewing machine General Fabrics, Light-weight materials and medium-weight materials Sewing Speed: Max. 5,000 s.p.m. Stitch Length: Max. 4 mm Needle: DBx1 #9 ~ #18 Presser Foot Lift: 10mm (standard) 13mm (max.) Price : $600 _______________ Consew 369 RB1 High Speed Post Bed Sewing Machine Double Needle Medium to heavy weight fabrics, leather, canvas, vinyl, synthetics and other materials Compound feet, walking foot Large hooks and bobbin case Can use the double needle feature or change to single needle on the right or left side Semi auto lubrication system Max Speed : 2200 Clearance under foot: 11/32’’ (8.5 mm) Needle Bar Stroke : 1 ¼’’ (32 mm) Stitch length, Max : 5 spi Needle Type : 135 x 7 Bed Size: 7’’ x 20 ⅜’’ (177 mm x 518 mm) Post Height : 7’’ (178 mm) Price : $4000 Commercial Shipping Available for all machines all machines come with clutch motor and table located in Bend Oregon
  3. I have a 25ton clicking press for sale, just finished being refurbished and works great. Located in bend Oregon.
  4. I've found the marketplace and have set a post there. Apologies for the screw up, couldn't find a way to delete.
  5. Hi all, I have been making custom brass heat stamps. They are made by use of a CNC machine and are quite accurate. Can make dies and plates that range from 1.75'' x 1'' to 6" x 14". I use 360 engravers stock brass to start. I've included some recent finished products. The black residue is from being stamped into coasters, hangtags, and a way to brand your products. I will upload pictures of stamped products soon. I am happy to answer any questions. prices range from $60 and up depending on sizes.
  6. Hello all, I have two refurbished Schaefer Cementers. They are the edge coating series. I have an 11'' and an 8'' for sale. 11'' cementer - $1000 8'' cementer - $800 buyer covers shipping, but willing to negotiate These machines do not have a heating element! Edge Coating Machine (model EC): The EC model is an edge gluer, which is a gluing machine designed for adhesive application along the edge of a part. This type of gluing machine has open end (cantilevered) rollers that allow adhesive application to either the edge of a sheet or to the full surface (up to the width of the gluing machine).Home Adhesives Adhesive Wax Hot Melt HM HRC Hot Melt Gluer New Label Cementers Sheet Cementers Smoothing Press Solvent Cementer Topside Coaters Adhesive Recirculation Systems Custom Machine Design Nip RollsMSDS What's New Widths, 3", 8", 11", 15" The adhesive coating thickness is adjusted by means of a dial which controls the gap between the pickup roller that sits in the glue tank and the coating application roller.The standard machine can glue parts from paper thickness to ¼ thick, but an optional model with floating feed roll can be used for adhesive application to parts up to 2" thick.The position of the feedtable relative to the coating roller is adjustable so the machine can be set for gluing a narrow strip along the edge of a part or can be used for adhesive coating of the full surface. The edge cementing machine can be built with special rollers for coating stripe patterns or for application of a stripe of adhesive a pre-set distance from the edge of the part.The Edge Coater can be used for the application of many types of adhesives - latex cement, dextrine glue, PVA and EVA resin cement, acrylic PSA adhesive, epoxy adhesive, ultraviolet cured adhesive, hot animal glue (heated glue tank), and many other types of coating and adhesive formulations. The machine is designed for easy cleanup, and has a removable glue tank and adhesive pickup roller. This design allows glue to be cleaned from the machine in less than ten minutes.Edge Coating machines are very popular for the application of latex cement to leather goods such as wallets, handbags and belts, as well as to shoe and boot components. These machines are also used for gluing many other products where a band of adhesive is needed: calendars, easel backs, sample books, specialty boxes, filters and toys are just a few of the other applications for these machines.
  7. Hello all, I have two refurbished Schaefer Cementers. They are the edge coating series. I have an 11'' and an 8'' for sale. 11'' cementer - $1000 8'' cementer - $800 buyer covers shipping, but willing to negotiate These machines do not have a heating element! Edge Coating Machine (model EC): The EC model is an edge gluer, which is a gluing machine designed for adhesive application along the edge of a part. This type of gluing machine has open end (cantilevered) rollers that allow adhesive application to either the edge of a sheet or to the full surface (up to the width of the gluing machine).Home Adhesives Adhesive Wax Hot Melt HM HRC Hot Melt Gluer New Label Cementers Sheet Cementers Smoothing Press Solvent Cementer Topside Coaters Adhesive Recirculation Systems Custom Machine Design Nip RollsMSDS What's New Widths, 3", 8", 11", 15" The adhesive coating thickness is adjusted by means of a dial which controls the gap between the pickup roller that sits in the glue tank and the coating application roller.The standard machine can glue parts from paper thickness to ¼ thick, but an optional model with floating feed roll can be used for adhesive application to parts up to 2" thick.The position of the feedtable relative to the coating roller is adjustable so the machine can be set for gluing a narrow strip along the edge of a part or can be used for adhesive coating of the full surface. The edge cementing machine can be built with special rollers for coating stripe patterns or for application of a stripe of adhesive a pre-set distance from the edge of the part.The Edge Coater can be used for the application of many types of adhesives - latex cement, dextrine glue, PVA and EVA resin cement, acrylic PSA adhesive, epoxy adhesive, ultraviolet cured adhesive, hot animal glue (heated glue tank), and many other types of coating and adhesive formulations. The machine is designed for easy cleanup, and has a removable glue tank and adhesive pickup roller. This design allows glue to be cleaned from the machine in less than ten minutes.Edge Coating machines are very popular for the application of latex cement to leather goods such as wallets, handbags and belts, as well as to shoe and boot components. These machines are also used for gluing many other products where a band of adhesive is needed: calendars, easel backs, sample books, specialty boxes, filters and toys are just a few of the other applications for these machines.
