Hey Bob.
Thanks for the reply. i think I understand what I would have to do to the cast iron body (3/8" material removed for needlebar/presserfoot clearance). I can do that no problem. Lifter handle bracket no problem, I will make a new one with a shorter slot. very good so far!
 I make the clearance but I don't modify the stroke of the needlebar? do I change the location where the needlebar clamp (connecting link with the two set screws) holds the needlebar? In essence, choke up on the needlebar?
If I understand this correctly:
 the stroke length will remain the same but the needlebar will be set higher so the stroke has been raised higher
Because the needle stroke is higher, it will not reach low enough  on the down stroke to catch the lower thread unless the needle is longer than a standard needle. (my needles are appx 2 3/4")
Here is my question:
If I use a longer needle wont I bring the needle tip back down to where it originally was? will I still have clearance for thicker material with the longer needle hanging down?
Any further clarification you have would be most appreciated!!!
Also, where did you source those needles you mentioned? I dont know where to get them.
Thanks!
