Hollywood
Everything posted by Hollywood
  1. Hi Kristy I can't see anything wrong from pictures / other than the wood dowel diameter is to large for the cord width you are using to determine the correct width required 3.142 (Pi) brought to closest decimal is 4 so multiply diameter of dowel 10mm / divided by number of strands you are using eg if dowel is 10mm diameter and you are using 12 strand braid = 10 mm ( diameter of dowel) multiply by (3.142) closest is 4 so you get 4.0 multiply by 10 = 40 divided by number of strands (12) So you need 12 strands approx 3.3mm based on this formula you should be okay Cheers from Australia
  2. Thanks Joe /RC I have this book and the info I require is as a footnote for another start as recommended by Ron Edwards Cheers John
  3. Looking for an Information for an alternative Start for a.... "Triple Stripe/ Goanna Neck Plaited Belt of 18 Strands" As detailed in the "Australian Plaiters & Whipmakers Journal " Article by Barney Belford "APWA" 1994 / April Page 567 Thanks John /Aust
