vonL
Everything posted by vonL
It's been a while since I last visited this thread, and not a whole lot of sewing, been busy with other commitments. Anyways, in addition to the 111w155, I found a cheap 111w153. I figured I can have one set up for fabric (denim etc) and one for leather and vinyl. The 111w153 came with quite a lot of schmetz 135x5 size 18 needles - what is the difference between this system and 135x16/135x17? I tried the web but am still blank. Could someone please enlighten me? Stefan:-)
Thanks Wizcrafts! I'll try and keep a close eye on the thread while sewing, to see if I can recognize whats going on next time this occurs. It suddenly struk me that the last project I am working on got stuck on the thumbscrew on the plate covering the bobbin Might be a good idea to remove the thumbscrew when sewing larger pieces. Before this Singer, the closest I got to sewing was my mom patching holes on the knees of my jeans. Learing how to sew is really satisfying - as well as learing a new skill (with which I can help others) I'd say there is a lot of mindfullness in it.
I've invested in a sailrite workhorse servo motor, huuge improvement, even more so than I expected. But, I am having a slight problem when sewing, which has nothing to do with the motor, it occured when using the clutch motor also. The problem is my machine sporadically produces inconsistent length stiches during sewing. It can sew fine, consistent length stiches, and then suddenly produce shorter length stiches during the run. Any ideas as to what might cause this, and is there any thing I can do to solve this?
Super! Thanks again, this was very helpful advice:-)
Aha! Great info - thanks guys:-) so I should be using 135x16 for leather (with it's various points) and 135x17 for fabric?
Btw I know which size of needle recommended, what I can't really find an answer to is needlesystem, tip/point and all that. Seems to be lots of different designations? (Let me know if my spelling is bad:-))
Hi ! It's been a while since I checked in, but 480volt - Yes, You are right - it is of course not dual phase, but 3 phase, with a huge white something into which the wires go, and this something lets the motor run on 220v single-phase (presumably?). Anyways, It is an old lump, singer 1/3hp 1425 rpm. Will have to do for a while until I can afford a servo-motor. I am in need of some advice, please let me know if I'm posting in the wrong forum. I will be using my 111w155 for both leather and fabric, ranging from light upholstery leather up to double layers of 4-6 oz chrome and/or veg tanned leather (Purses, totebags, motorcycleseats, etc), and all sorts of items in canvas and denim and other heavy fabric. I've read that the 111w155 will work with thread in the range of 69-138. I am having a hard time figuring out what sort of needles i should buy. If I was to buy 1 spool of all three thread thicknesses, and needles accordingly - which needles will I have to buy? The more i read and surf the web, the more confusing it gets:-/
Oh - and the "chug-a-chug-a" of the walking foot is just NICE! :-)
I've been reading alot on the web about old clutch motors and how incontrollable they seem to be. Also, the look of the motor on my table didnot add much to my confidence, being an ancient 110v 3phase converted to 220v 2 phase, full of dust and filth. I was sure buying a new servo motor was a must. I havent even tried to start the old clutch motor. To be honest, I was afraid it would either give me a huge ZAP!, blow a fuse or catch fire, while sounding like a jetplane indoors. That was until today. I figured I might aswell jump feet first, ignoring the thoughts of a possible hazardous outcome. Boy was i wrong! I flick'ed the switch (what a Nice switch btw, an originial singer all-metal switch with a really pronounced 'click') and the motor started right up, no problems! It has the typical clutch motor sound (I actually like the sound - for now). And it is really not that incontrollable, I'm sure it will be even easier to controll if I change the pulleys. Next step is aquiring some thread and let it rip:-) I have some schmetz 21 dp leather needles (came with the machine), am going for size 92 thread to try out. I need to clean the stitch length mechanism, as it won't change length. When I engage the left button, I can hear a slight "twang" inside the machine, but no movement in the length selection mechanism
Hi folks ! Thanks for the advice! Will try some of the tricks mentioned. Working hard right now to get my workplace Nice and tidy with some new paint and shelves. Really looking forward to get a Nice place and a servomotor, and get going. I've seen some nice deals on the enduropro motors. 220v. Are they any good?
Yes, not the big one which slides inside the machine casting, but inside the tensionplate. I'll get some nails in a suitable size and give it a go:-)
My machine now has a new timing belt, and I've adjusted the feet. I need a new thread tension release guide, mine is broken, but now I know how to change it, and have all involved parts cleaned, it will be an easy fix. The small pin in the thread tension plate is missing - what length is this pin? I figure I could fabricate one easily enough as long as I know the dimensions
Thanks for the tips - will check the rotary hook this weekend. I've read that this machine is for medium to heavy fabric, and will probably not be of any use to me, so it will be up for sale again as soon as I know that it works. I belive the market for such a machine is pretty small in Norway, so I'm hoping it'll cover å new servo motor for my 111w155
Will post pictures soon, it's currently stashed at my grandma's place:) I forgot to write that the hand wheel can be moved a couple of centimeters back and forth, and it feels and sounds like if there is a slot in which a certain movement in the mechanism is allowed. No movement of the needlebar when this action is performed, and it is more of a metal meets metal feeling and sound, rather than gummed up parts. Does that make any sense?
I just bought a very nice singer 196k205 with a pfaff table motor, got a super deal (40usd) and couldn't resist. I understand that it won't be any good for leatherwork as it's not walking foot or needle feed? I bought it with the intention of re-selling and financing a servomotor for my 111w155. Anyways, the machine, table and motor is cosmetically super nice, it's been used by a former clothing seamstress (is that the correct term?) BUT - it won't turn. Seems like something is stuck inside the machine. I removed the drive-belt so it's free of the motor. Is there a locking mechanism in the machine? Presser foot lifts without problems.
I watched Uwe's video on changing the thread tension release guide, and found out that it was bent on my machine (where the lift arm meets the thread tension release - does this make sende?). Bent it back just to test, with the result of even less presser foot lift. I then found out that since every moving part is dirty and gummed up, things weren't moving as it's supposed to. After cleaning with wd40 and some gentle prying I now have what seems like correct lift, but the inner foot now binds on the feed dog. I'm going to adjust as per some other thread on this forum as soon as my timing belt arrives, and will also get a new thread tension release guide.
Thank You Wizcrafts, will dive into the manual later today:-)
Hi folks! Last week I bought my first sewing machine, a Singer 111W155 with table and original clutch motor, I paid 35 usd. It's been sitting for quite some time and is in need of a good cleaning, lubricating and adjusting. The timing belt was broken so I have not been able to test it, but it turns over by hand. Timing belt should be here in a week or two, eager to test it. I think there is an issue with the foot lift mechanism - it binds when i use the knee lift, I have to gently push down on the linkages on the back of the head. Max lift is around 4-6mm it seems. I'm being gentle with it as I am afraid of breaking something. I have not been able to locate exactly where it binds, but it seems to be the parts of the mechanism on the inside of the head. I will post pictures with arrows this evening. I dont know of any place who can do a service on this machine om Norway, so i guess I'll have to manage myself and I am up for the task. Stefan
