piper01
  • Content Count
    6
Everything posted by piper01
  1. I just want to chime in. I have been reading the post and I was having foot lift problems. I was going nuts trying to outer figure foot lift. I put hours into research. I found the screw for the lifting block and pushed the block down towards the back lifting arm and now I have outer pressure foot lift approx. 5/16. Thank you for your help.
  2. The presser foot was lifting nearly 3/16 inch when sewing, then something happened. I will play with it more to try and restore presser foot to lift higher when sewing. Thanks to all of you for your responses.
  3. Thank you for your post. It helps clear some of my questions. Great pictures. But I must be doing something wrong. The Max lift I can get on the presser foot when sewing is 1/16.
  4. Thank you for your post. It helps clear some of my questions. Great pictures. But I must be doing something wrong. The Max lift I can get on the presser foot when sewing is 1/16.
  5. What is the max foot lift when sewing.
  6. I can't get the presser foot to lift. It was working then changed sewing foot and it started to bind and I think I put to much pressure and no I can't get it to lift when moving the wheel. I tried to adjust the height with the big screw in the back of the machine but no matter where I set it no lift.
