Bluestar
Everything posted by Bluestar
  1. Hi, I'm new to this forum but this seems like the right place to get some help and opinions on my new machine. I picked up this machine using fb marketplace for $250 Canadian after searching for a few weeks. The seller mentioned her sister worked in the apparel industry and used the machine for her personal non-work projects, it was not a company machine. When the seller came into possession of the machine she found it overkill for her projects and preferred her singer domestic machine instead. It seems like its in very good shape mechanically, the paint has seen better days. It has a clutch motor but I plan on replacing it with a servo. The insides have a fair amount of built up lint, I suspect from using excessive oil and infrequent cleanings. I'm planning on using it for some projects I have in mind - canvas tent, backpacks and anything else that pops up. I'm hoping you all can help me answer the following: - is this as good of a deal as I think it is? - any good videos of the teardown and rebuilt would be much appreciated, youtube wasn't so helpful it seemed - any recommendations of needle, thread suppliers (preferably a member of this forum) in the Greater Toronto Area or in Ontario, Canada in general - what is the best way to clean the machine, I'm guessing isopropyl and a cloth/toothbrush? - should I clean the machine first, re-oil everything and then test it? or should I test it, troubleshoot and then tear it down, clean, and replace any parts at that stage? - the reverse paddle doesn't seem to go all the way back up when its depressed, could this mean the spring needs to be replaced or is that normal? - a good resource on how to tell the best thread size and needle combinations, and what thread size to use in my various projects - it came with U size bobbins but the owner had it set up with a pre-loaded 'bobbin' made of cardboard, see pictures of bobbin case - what's that about? - I read somewhere the walking foot could be removed, some parts replaced and it would function as a quasi-needle feed machine, is this true? - would a servo motor with needle positioning be helpful enough to warrant the upgrade cost? My main Brother machine has needle position, auto beginning/end lock stitching and thread cutter, its the bee's knees. Yes I am aware I have a bike addiction, apparently its spread to sewing machines now too. Thank you,
