glock 17,22,31,37 Full size
20,21 Full size
19,23,25,32,38 Compact
26,27,28,33,39 Sub Compact
29,30 Sub Compact
36 Compact slim 45
Just in case, each line of model numbers is same size.
I would not use a liner if it is a modern gun coating, they will wear better then one would think. or you could do one like the milt sparks summer special ( rough side out ).
8.50 sounds high IMO. a full side could be a bit much for your first. Call Springfield Leather they should be able to give you a better price and they will cut so you don't get stuck with a lot of leather , a side will make a lot of holsters.
BTW shipping on the leather is not as bad as one would think. and if you have questions springfield will answer them.
Kevin must have spent 30 min on the phone with me on my first order. (PLUG)
Are holster liners needed and maybe in what situation, if so I need some opinions on a good liner for concealed holsters. I am using 6/7oz. H.O. from springfield leather co.
The holster looks good brother Carl. I am going to try a holster with the same kind of loops ,are the belt loops held on only buy the back part of the snap, or do you use some Cement ?
loos good , the edge takes time to learn, you have to get a smooth cut and the mosture content of the leather needs to be right. some people use diffrent cems. on the edge but if you can learn when the leather is right it will burnish great. it is still hit and miss with my holsters. BTW where did you find the working tools stamp.
