CitroenLVR
Posts posted by CitroenLVR
  1. Hi All,
    Just picked up a Consew Cylinder bed machine. It is a compound needle feed machine. Can someone identify the model # of this machine?
    Sadly I assumed that Consew could look up the model number using the serial #. After calling corporate today I was told that they cannot. What?
    It has an oil reservoir on the top front which you can see in the photo below. The table top is solid with no oil pan or hole in it under the machine.
    Also does anyone have a Stitch length position plate for this machine?
    Thanks in Advance, Garric
  2. Thanks kgg and Wiz,
    The issue resolved itself today. I put foaming oil on all the reverse lever parts I could find yesterday. Apparently after sitting the lube had a chance to work, one day later and I'm golden.
    Also the stitch length dial works if I press the reverse lever. Odd, but at least I saved the $100+ the mechanic would have charged.
    I appreciate all the advice Gentlemen!
    Garric
  3. Thanks Kgg,
    Can't see where it's rubbing. Maybe the machine was resting on the lever when I transported it in my car.
    Added some oil around the area where the pin shaft goes through the body to no avail.
    Can't see where the lever mechanism is as it is deep in the body of the machine.
    My mechanic would charge me $100 to fix so I'd like to do it myself of course.
    Any other advice?
