makeallthethings
Everything posted by makeallthethings
  1. I would bet the 150 grit sanding is the culprit and likely causing the edges to fluff up and probably worse than if you didn't sand at all. If you want a gloss finish on the edges then 400 grit at the minimum but I go to 600 and as I finish sanding, during the last few minutes I sand in only one direction and lightening the pressure
