fredk - thank you for the input, considering it doesn't hurt skin, that was my guess after not seeing any issues, but wanted to check considering I don't see anyone using it.
chuck123wapati
That's funny you should mention it, I use a pumice stone on car clear coats to get rid of drips and runs. It' works very well because it doesn't conform to shape of the drip, which sand paper does. Soak it for about 10 minutes then use a lot of water, it does require quite a bit of elbow grease, but that's why it can be used to polish, as noted in your post. Many custom painters prefer to use what's basically a miniature wood plan instead because it's quicker and less work. I also use them on my hands and feet to remove dead skin, so while it does come from a volcano, it's not exactly like pouring lava on something. the gloss being removed is very different than roughing up the surface to create a physical tooth to get the glue to penetrate. I have no doubt if i just scrub with a rock on leather it would do damage, but that's not remotely what I've asked about.
