TowRigger Report post Posted April 12, 2022 Dont know if anyone else has done this or not, but used the draw feature on my cricut with some plastic sheets to create pattern templates. you still have to cut them out but the lines and measurements are straight and exact. hopefully this helps other people if they have a cricut cause even with a ruler i can draw for beans. Quote Share this post Link to post Share on other sites
GritMercantile Report post Posted May 8, 2022 We have been doing this for some time. We use Adobe Illustrator to design the panel, export as SVG, import into the Cricut software cut out the template on quilters plastic. If you choose the .37" chipboard as the material and choose "More" in the cut setting it will go over the design twice. Then when it is done cut it again. It will pretty much cut thought the plastic and you have exact size panels. We have also use chipboard in our Cricut maker as well to make templates. Quote Share this post Link to post Share on other sites
