Decided to make a combination crossdraw holster and mag carrier for my Kel-Tec P3AT
Seems to ride fairly well, but next time I need to raise the loops and reduce the cant a bit so the gun rides lower.
Edited by TexasGeezer
Great looking piece. But I've got a question. I'm not a holster maker so bear with me. I have done several holsters, some cell phone cases and knife cases with the same type of belt attachment. In my case I wrapped the strap so it inserted from the top, wrapped behind the belt and then snapped in the front. Sorta upside down from yours. The thought being that if the snap popped the strap would have to slide up behind the belt then over before it would drop. Is this a concern? Or am I just doing overkill?
Keep on Smilin
Jim
Wow, that's really a great-looking holster! I'm impressed with how well you've molded the leather around the gun. . . What weight leather is good for this?
I really like that type of holster. . . :specool:
L'Bum
Thank you! :cowboy:
Jim, I vacillated over your question awhile before I made my first and now this holster. All of the "commercial" snap on type holsters I've seen have the straps as you suggested.
My rational for making it as you see was that:
1. I think it looks better with the straps pointing down.
2. Seems like, over time, with the straps pointing up, they might tend to pull away from the body and sort of protrude out.
3. I wear my belts pretty snug and, should a snap open, the strap would have to pull away behind the belt, with the snap tending to hang up on the edge of the belt.
4. I have to "suck it in" a bit to remove the holster while wearing it, so I don't think it could pull loose very easily.
5. The P3At is a very light "pocket pistol" so doesn't really add much weight to the holster and the fit, while firm, is not tight enough to move the holster when I draw the pistol.
6. I did pose the question on this forum and a professional holster maker answered, voicing about the same reasoning you did, fearing that if the straps were like I made them, the holster could come along with the gun in your hand during a draw.
Bottom line --- After considering all of the above, I just decided to go with it as shown.
L'Bum, The leather mic's out at just a hair under 0.1", so that makes it about a 6 to 7 oz leather, based on what I could find out on the Internet, comparing thickness to weight of leather. The guy at Tandy sold the skin to me as "5 to 8 oz", which I guess is about right. As I said above, the P3AT is a small, light pistol, @ about 7.2 oz empty and maybe 12 oz max loaded, so this weight leather works well. I suspect it may be to thin for a larger pistol, although it does form nicely. I'll probably try to make a similar holster for my S&W M&P 9mm compact, which weighs 24.6 oz empty and probably around 35 oz loaded, so it's about 3 X heavier than the M&P. I'm thinking about perhaps using a heavier leather for the back piece and some of the 6 oz for the front.
