Members ThomasBH Posted August 4, 2022 Members Report Posted August 4, 2022 Hello, My Pfaff 145 was working fine for months, then all of a sudden after changing out feet the outer foot will not raise. Only the hand/knee lift will raise it now. If I look real close it moves about a mm when the inner presser foot is at BDC (bottom dead center) I've puzzled through all of the adjustment guides on the 1245 as well as google searches and can't find anything. Any suggestions? Thanks Quote
Moderator Wizcrafts Posted August 4, 2022 Moderator Report Posted August 4, 2022 Try reinstalling the stock feet. Does that fix it? If so, the replacement/aftermarket feet may be the wrong height. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members ThomasBH Posted August 4, 2022 Author Members Report Posted August 4, 2022 Thanks for the suggestion, but no, even with no feet attached watching the machine cycle the outer bar barely moves up and down at all, just a mm or two. Quote
Members ThomasBH Posted August 4, 2022 Author Members Report Posted August 4, 2022 Solved! I guess that a "partially" compatible foot (cheap Aliexpress crap) must've knocked the other foot out of timing so the foot wasn't arriving at the exact time as the needle reached the bed, and only when it reaches at the same time does the 2nd foot actually raise and lower when the inner foot is at the bottom. It has an interesting mechanism for sure! Quote
