RC65 Report post Posted January 6, 2023 I’ve poked around a little bit with a keyword search on this subject and really haven’t had much luck. My question is… is there a setup that someone has done to pull remnants out and reduce some of the buildup on roller and inside bell? Im using the consew dcs-s4 Quote Share this post Link to post Share on other sites
FDC Report post Posted June 19 I have done this to my Techsew skiver. I have a shop with a central cyclone extraction system that has 5” flexible hose at the end of each line. I simply put a 5” plastic fitting up under the bottom of the skiver table where the leather drops out, hook up the extractor and good bye leather scraps. It was dead simple. You can utilize what you have but keep the port mouth as big as possible. A good shop vacuum would work. Quote Share this post Link to post Share on other sites
