I make watch straps and straps tend to be in MM's  Thing is.  Nobody makes V punches in mm's.  Found one seller, but designed to align in imperial widths
Surprising that the majority of the world works in metric.  Some tools still made in imperial.
As to widths.  If I bought a 7/8"  The widest opening is not 7/8", but 15/16" and this size is under 24 mm, so I have to move to the next size up which is 1" (1 1/16") or 3 mm wider than 24 mm (works for 26 mm wide straps).
This leaves a slightly stunted tip rather than a little more elongated one
No plan on replacing the punches I have.  Just curious
Thanks
DON
I get such things out of China. All measurements in millimeters
The last few I bought are not handled punches but for use under a press, but I have round and V end handled punches, all in millimeters
I have 2 from China.  A half round 20 mm, but the other 20 mm is more of a slanted cut with round tip rather than elongated design
Since most of mine are Osborne punches.  Doesn't pay to run out and buy replacements
Thanks
DON
Edited by DONAG
