CFM Frodo Posted June 7, 2023 CFM Report Posted June 7, 2023 I have modified my press on one end of the presser ram I pressed a 1/4” rod coupling into the hole then machined the protruding end of the coupling to fit the lg stamps. See image on the other end, drilled a hole to slip the bits from a hand punch into see image the anvil that came with the arbor fits into the rod coupling, I use it when pressing large stamps, at this time I can use a 6” stamp Quote
