Members YinTx Posted June 20, 2023 Members Report Posted June 20, 2023 Very cool work. Easy to over engineer that, and I think you did the right amount! Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members TomE Posted June 20, 2023 Members Report Posted June 20, 2023 (edited) On 6/17/2023 at 5:11 PM, SeaCitadel said: Main body edges are a bit fuzzy because I only water slicked them, and this before wet molding. Not sure if I'll bother correcting this. Bridle leather is difficult to burnish - fluffy fibers stuffed with fats and waxes. The best method I've found is to dye the edges with a 50:50 mixture of Pro Dye and Martin's Edge Solution then burnish while wet. Be generous with the dye/edge solution. I start with a wooden slicker on a burnishing machine then finish with canvas but canvas only will also work. Can do a bit of sanding then apply another coat if needed. Your file organizer is first rate craftsmanship. Edited June 20, 2023 by TomE Quote
Members SeaCitadel Posted June 23, 2023 Author Members Report Posted June 23, 2023 On 6/20/2023 at 1:26 AM, Bert03241 said: That letter A looks familiar , like from a White Collar episode Can you elaborate? I'm not familiar with white collar, but I'd love to know how they copied me On 6/20/2023 at 4:02 AM, Wepster said: To further my learning, where do you think you should have placed the studs? Lower? above the keepers, with the keepers lower? Not used studs? I think I should have used only studs, no keepers. I wouldn't trust the keepers alone to keep the lid shut. I added them to keep the studs closed, but this is my first use of Sam Browne studs and it turns out they can withstand a good pull before opening. On 6/20/2023 at 2:33 PM, TomE said: The best method I've found is to dye the edges with a 50:50 mixture of Pro Dye and Martin's Edge Solution then burnish while wet. Be generous with the dye/edge solution. I start with a wooden slicker on a burnishing machine then finish with canvas but canvas only will also work. Can do a bit of sanding then apply another coat if needed. I don't have much of the bridle left after this project, but those are great tips if I ever pick up more. Thanks all for the comments and tips. Quote
Members Wepster Posted June 23, 2023 Members Report Posted June 23, 2023 10 hours ago, SeaCitadel said: I think I should have used only studs, no keepers. I wouldn't trust the keepers alone to keep the lid shut. I added them to keep the studs closed, but this is my first use of Sam Browne studs and it turns out they can withstand a good pull before opening. Thanks all for the comments and tips. Thanks, I do think the keeper adds a certain finished look the piece. Maybe finished is not the right word, but they add a secure (?maybe?) look. If this were a purse I would think the keepers would add a big degree of difficulty to having the contents stolen in a crowd or hanging on a chair back in restaurant. Conversely I can see where they would add, for the same reason, an annoyance when retrieving documents in your home. With or without, a wonderful result for what I am sure was a lot of work! Quote
