Members BreeKal19 Posted November 6, 2023 Members Report Posted November 6, 2023 So I left out a tray of pro dye to the point that it's evaporated off to being almost all the way dry. Has anyone ever tried reconstituing their pro dye? In my head it seems like it'd work. I usually cut 50/50 with 91 isopropyl alchohol anyways. Wonder if a splash enough to pick up the pigment from the pan would work out or if the dye will be too altered by then. Curious if anyones tried it! Happy crafting Quote
Members Littlef Posted November 6, 2023 Members Report Posted November 6, 2023 Its probably not going to work, but a bottle of isopropyl is cheap. Its worth a try. If you get it to dissolve in the alcohol, use a scrap test piece before trying it on your actual project. Quote
