Members Cattleman Posted August 7, 2024 Members Report Posted August 7, 2024 Ranger Belt... Usually made with a fancy buckle, loop, and tip set. The pictures above are a ranger belt minus the fancy hardware. Quote
Members Handstitched Posted August 15, 2024 Members Report Posted August 15, 2024 G'Day, The 3 piece belts I have made in the past were made up of off cuts long enough to make a usable belt. First piece the buckle end, then a D ring ( or an 'O'ring or square ring) , then a middle piece, then another D ring and then the billet, hence the 3 pieces. Each piece can be tooled, carved etc. the middle piece for example, can also be a different colour to the rest of the belt. The off-cuts can be turned into quite a unique one off belt. The sky is the limit for ideas and designs. Hope this helps . HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members DoubleKCustomLeathercraft Posted September 19, 2024 Members Report Posted September 19, 2024 There's a leather company up here in Montana that does custom belts. I can't remember the name of the top of my head. They have 3 piece belt, and what this does is allows them to produce the two ends (buckle and billet) at standard lengths, then the custom part is sewn on and sets across the back. They also refer to these as 3 piece. Dunno if there's a right or wrong answer, because any belt with 3 pieces essentially falls into this category. Quote
