kgg Posted August 10, 2024 Report Posted August 10, 2024 5 minutes ago, JWfur said: What would the 4800 be in the other brands? The Techsew 4800 would be sort of similar to Juki LS-1342 in that it has a adjustable presser foot climbing mechanism. Looking at the photo's on their website it has the larger diameter nose like the Juki LS-1341 and their model 2750. The difference between the Juki LS-1341 and a Juki LS-1342 is basically the presser foot climbing mechanism and the smaller diameter nose which maybe beneficial for smaller items. What I did notice is the spec's for the Techsew 4800 says it is capable of handling V277 but it can only handle a #24 needle which is good for V207 so I think that maybe a typo in Techsews spec's. As a note that the Juki LS-1341 and LS-1342 can handle a #24 needle but it appears they rate their machines for the max size of thread for the max sewing thickness not thread size capability of the needle. My conclusion: i) if you need an adjustable presser foot climbing mechanism in a clone machine with similar spec's as the Techsew 4800 then maybe investigate something like the THOR GC 1341 ii) if you need a smaller nose and the presser foot climbing mechanism buy a Juki LS-1341 which is going to cost a lot more. iii) if you can do with a clone machine having a slightly larger gauge nose and no presser foot climbing mechanism like the Juki LS-1341 then look at the Cowboy CB341, Cobra Class 26 and Techsew 2750 to name a few. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members JWfur Posted August 11, 2024 Author Members Report Posted August 11, 2024 5 hours ago, kgg said: The Techsew 4800 would be sort of similar to Juki LS-1342 in that it has a adjustable presser foot climbing mechanism. Looking at the photo's on their website it has the larger diameter nose like the Juki LS-1341 and their model 2750. The difference between the Juki LS-1341 and a Juki LS-1342 is basically the presser foot climbing mechanism and the smaller diameter nose which maybe beneficial for smaller items. What I did notice is the spec's for the Techsew 4800 says it is capable of handling V277 but it can only handle a #24 needle which is good for V207 so I think that maybe a typo in Techsews spec's. As a note that the Juki LS-1341 and LS-1342 can handle a #24 needle but it appears they rate their machines for the max size of thread for the max sewing thickness not thread size capability of the needle. My conclusion: i) if you need an adjustable presser foot climbing mechanism in a clone machine with similar spec's as the Techsew 4800 then maybe investigate something like the THOR GC 1341 ii) if you need a smaller nose and the presser foot climbing mechanism buy a Juki LS-1341 which is going to cost a lot more. iii) if you can do with a clone machine having a slightly larger gauge nose and no presser foot climbing mechanism like the Juki LS-1341 then look at the Cowboy CB341, Cobra Class 26 and Techsew 2750 to name a few. kgg Thank you, I'm in the process of checking on the machines you mentioned. Quote
kgg Posted August 11, 2024 Report Posted August 11, 2024 11 hours ago, kgg said: if you need a smaller nose and the presser foot climbing mechanism buy a Juki LS-1341 which is going to cost a lot more. I made a mistake. It should have said Juki LS-1342. @JWfur kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members JWfur Posted August 11, 2024 Author Members Report Posted August 11, 2024 That Juki 1342 sounds awesome in the description. However the price about tipped me over. Too much for me, unless I could find a used one. I'm still looking. @kgg Quote
kgg Posted August 11, 2024 Report Posted August 11, 2024 1 hour ago, JWfur said: However the price about tipped me over. I figured the price would catch you a bit off-guard. When I bought my Kobe LS-1341 I had actually gone to buy a real Juki LS-1341 but the new Kobe was a lot less so I said I'd give it a try and if I didn't like it I would sell it. Well I basically kept it for 3 years with no problems before I sold it. I usually keep a clone for about 3 years whereas the Juki's stay. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members JWfur Posted August 11, 2024 Author Members Report Posted August 11, 2024 So just curious. Why keep them 3 years and sell? I'd assume it's not a wear and tear problem, seems like 3 years they'd just be broke in? Quote
kgg Posted August 11, 2024 Report Posted August 11, 2024 1 hour ago, JWfur said: So just curious. Why keep them 3 years and sell? I'd assume it's not a wear and tear problem, seems like 3 years they'd just be broke in? Your right it is not a wear and tear thing as I keep my machines in pristine condition and when I sell them they look like they just came out of the box. What I have found is at that time frame the price of a new clone, for that model, has increased allowing me to usually get what I paid or close or more and move on to something else. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members FDC Posted August 12, 2024 Members Report Posted August 12, 2024 I have a Techsew 5100. I’m a novice leather worker. This heavy duty machine has worked flawlessly for me using heavy to light set ups. I’ve run #19 needles and #92 (?) thread on leather, rubber and marine vinyl with good results. The heavy stuff? Not a problem, I’ve sewn 0.80” plastic an it didn’t even register as tough. Likely more machine than most leather workers would ever need unless you’re making sheaths, holsters, saddles and protective equipment. Download the manual and parts list, be curious about how it works and try to get it optimized every chance you get. That’s how to climb up the learning curve in my opinion. Quote
