Members alpinelite Posted October 19, 2024 Members Report Posted October 19, 2024 Hello, I got lucky and found Bernina 217 with all the original cams (20 cams) and cam reader. Cam reader works but I would like to move it to my other 217 I am currently using. Both machines are 6mm zigzags. Anyone knows how to remove the Cam reader and re instal it? Amongst the original cams there is a Cam with nr. 10113 but I believe that's not 3 step zigzag cam despite being pictured as such in the original (German) manual? Thank you! Quote
Members alpinelite Posted October 23, 2024 Author Members Report Posted October 23, 2024 Anyone that can help? Thanks Quote
Members Constabulary Posted October 23, 2024 Members Report Posted October 23, 2024 (edited) IIRC the 217 came with 2 different cam readers. I think the later model is the 217N and it is using larger cams. Which one do you have please post some pictures. Edited October 23, 2024 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members alpinelite Posted October 24, 2024 Author Members Report Posted October 24, 2024 17 hours ago, Constabulary said: IIRC the 217 came with 2 different cam readers. I think the later model is the 217N and it is using larger cams. Which one do you have please post some pictures. Thanks, its older version with small cams....same cam size as domestic 830 model. Both 217 are old versions 6mm zig zags. Thank you Quote
Members nejcek74 Posted January 7, 2025 Members Report Posted January 7, 2025 Here is a video of rebuilding the machine (in 6 parts) from a retired Bernina mechanic: https://www.youtube.com/watch?v=PVbA1gH1dWY&t=9s and here he is adjusting the Bernina https://www.youtube.com/watch?v=qoXRnmFJ2N8 but as far as I have seen, there is nothing about the cam box in those videos. Do you have the exploded view of Bernina 217: https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://www.supsew.com/download/Bernina/Bernina%20217.pdf&ved=2ahUKEwjVos3-l-OKAxUmhv0HHVz6MPQQFnoECA4QAQ&usg=AOvVaw1R4bnPRV_xIhOwSZW3inpU good luck, post the results of your work here :)))) Quote
