hi there…just bought a new-2-me pfaff 23-10 cylinder machine… having issues with tension mechanism on the face plate…
1. check spring is quite mangled…anyone have a spare or know of a singer? crossover…
2. on the back of the tension assembly(inside face plate) shouldn’t there be a rod of some sort (traveling inside the mechanism) to force/allow tension discs to release when foot is raised ??? mine is missing this ‘rod’… ( hope this makes sense!!!
thnx in advance,
steve
Please post pictures of your machine and the parts you have problems with.
The Singer 17 is a very similar machine if you need a manual look up a Singer 17 Manual. However here is a German language manual for your machine.
Not sure if the Singer 17 parts are interchangeable but in case you do not find a spring I would try a complete new Singer 17 or Singer 16 tension unit. Not a big loss if it does not fit:
https://www.ebay.com/itm/191942998278
https://www.ebay.com/itm/143871720894
Pfaff_23_Manual_-_German.pdf
Edited by Constabulary
thank u ‘sew’ much 4 manual access!!! any chance u have access 2 a parts manual???
