Members Zuzana Posted February 15, 2025 Members Report Posted February 15, 2025 Hi guys what hot stamping machine works best for biothane? I would like to buy one but not sure what to look for. Any recommendation whats best ? Quote
Members Cumberland Highpower Posted February 15, 2025 Members Report Posted February 15, 2025 I used to work miles of Biothane, what are you using? I ran mostly Beta When you say hot stamping, you mean an embosser or foil type machine, right? About any will work. If you're talking about a hot cutting machine, if you're running beta it depends how thick. SH Beta is hard to run through a hot cutter, you have to set the machine to run as slow as possible. I often resorted to a lube pad made from foam to lube the top surface, that aided surprisingly allot in the cleanness of the cut. Quote
