Members DenimHead Posted February 28, 2025 Members Report Posted February 28, 2025 Hello. I am a sewing machine tech, but I am stuck on something and I am reaching out to the community for advice. I have a Juki 563 that will not sew less than six stitches per inch. I know that it has the ability to do four stitches per inch, but everything I do will not get it below six, including adjusting the feed graduation disc. The eccentric appears to be in the right place and the machine is feeding correctly. Do any experts know how to adjust the machine to get it to four stitches per inch? Quote
Members Constabulary Posted February 28, 2025 Members Report Posted February 28, 2025 are forward and reverse stitch length equal or is the reverse longer - probably. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members DenimHead Posted March 1, 2025 Author Members Report Posted March 1, 2025 The reverse is slightly shorter. Do you have insight on how to equalize them - and to adjust the machine to do four stitches per inch? Quote
Members Constabulary Posted March 9, 2025 Members Report Posted March 9, 2025 (edited) since it is a (more) modern clone of the singer 111G / 111w I´d assume it is mentioned in the manual. I´ll check my records. EDIT: Not sure if the 563 is entirely the same but this extract is from a Singer 111 manual - hope it helps Edited March 9, 2025 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
