Members Tigweldor Posted 14 hours ago Members Report Posted 14 hours ago Hi, When the Corona lock down started in 2020 , I wanted to sew masks for myself, family and friends. Having absolutely no experience in sewing plus not owning a sewing machine - I started from scratch. My first sewing machine was a Pfaff 138-6-U - before I knew it, I owned two of them. One I gave to my sister - the other one I kept for myself after having built the table top from 10mm aluminum and having mounted a VFD to change top motor speed on the old clutch motor. I can also reverse sew with a touch on the second pedal - and of course installed a knee lever. All parts were bought individually. Quote
AlZilla Posted 14 hours ago Report Posted 14 hours ago Very nice, very sleek looking. How do you like that aluminum table? I have an aluminum table for my 441 clone. My work space is not well heated in winter and it makes my hands cold. Quote
Members Tigweldor Posted 14 hours ago Author Members Report Posted 14 hours ago The 138 is a pretty good Zig Zag machine - but in thicker leather is lacks power. So I bought an Adler 5 - and manufactured a speed reduction for it. I also use it with a clutch Motor in combo with a VFD All presser feet were polished - as well as the sewing guides I have a second pedal to raise the presser foot - had to make the lever in the back of the machine from an old Pfaff lever though Quote
Members Tigweldor Posted 14 hours ago Author Members Report Posted 14 hours ago @ AlZilla, I like the aluminum table top - it is longer than a stock table top and material glides on it well. I keep my machines in my "sewing room" - which is inside the house Quote
Members Tigweldor Posted 14 hours ago Author Members Report Posted 14 hours ago (edited) well, having been bitten by the bug, my next machine was a Dürkopp 239-3 walking foot needle feed machine - I also run it on the same VFD as the one for the Adler 5 Presser feet can be obtained from ebay/AliBaba for the Juki walking foot machines - they fit well. I like to mount my thread spools horizontal - makes less of a mess with loose threads jamming up under the bottom of the spool. Plus (this may just be my opinion) : if you stand the spool upright and pull of some thread - you have a major coiled thread dangling in mid air. You pull thread of a spool mounted horizontal - the thread does not coil - it comes of straight. I have done this on all my sewing machines. Edited 13 hours ago by Tigweldor more pics found Quote
Members Tigweldor Posted 13 hours ago Author Members Report Posted 13 hours ago (edited) other sewing machines : Adler 167 (sold), Kansai Special belt loop sewing machine, Adler 4 flat table walking foot and my newest purchase last week is a Gritzner sole stitching machine with #4 cover plate, a #4 needle and a leather knife transporter. It is in mint shape - the little alcohol burner has never seen use nor has the basin for gum tragacanth/oil for the top thread ever been filled. Bought it off a guy who bought a house that belonged to a deceased cobbler - had to drive 120 klicks (one way) - but it was worth it. I oiled it well and it works like a charm - will post pics after I have made some. If anyone needs needles size #4 or size #5 - I have searched the internet and found a source that sells packs of 10 needles for 92€ - that is less than 10€ per needle. Other sellers want horrendous amounts for that little bent piece of round stock (etsy : 761 PG needle = 27€ PER NEEDLE) If interested, send me a message and I will give you contact data. Edited 11 hours ago by Tigweldor Quote
Members Tigweldor Posted 13 hours ago Author Members Report Posted 13 hours ago (edited) Oh, I forgot : I have also own(ed) several singer 29K - a 29K56 that I sold and a 29K33 that I mounted on a custom stand with a gear reduction motor mounted in such a way that gravity on the motor tightens the belt, but I can raise the motor to eliminate belt tension via a parking brake from an old Hummel walk behind tractor to crank the machine by the hand wheel. The unit also uses a VFD and a foot pedal - it sews real nice. A quick tap on the pedal equals about 1/8 stitch. This is a long arm 29K33 with the larger 20mm bobbins - tomorrow I will buy a Singer 29K56 with a short arm (thought for parts for my Adler 30-7) The last pic is just doodling after a few brews to get my ideas onto paper before I start building - I do this with most of my projects And yes, I know - the bolts are too long - I meant to change that a while ago but they don´t bother me - so I haven´t done it yet - but I promise to better myself . The brass handle to fit a man´s hand I turned on a lathe and polished it - BUT - it is to heavy, so when the machine is not under belt tension it moves the hand wheel until the handle sets at the bottom - very anoying - needs further lightening on the lathe on the handle inside. Edited 11 hours ago by Tigweldor Quote
Members Tigweldor Posted 12 hours ago Author Members Report Posted 12 hours ago (edited) Here is a very unique open arm sewing machine - a Heinrich Koch open arm saddler sewing machine built around 1895. There is not one single gear/sprocket on this machine - all action is produced/transmitted via cams, cam wheels and levers. Stich length can be changed directly on the revolving sewing head via thumb screw - in my eyes technically leaps ahead of later built Singer 29Ks and Adler 30s --- on the second pic the thumb screw on the lower head pointing towards the hand wheel I also like the way the machine body is hand painted with tear drop / dragon scales - this was made in the days before they used decals to pretty up sewing machines. Edited 12 hours ago by Tigweldor Quote
Members Tigweldor Posted 12 hours ago Author Members Report Posted 12 hours ago (edited) I got the Heinrich Koch for a decent price as it was missing the bobbin winder - which even in Germany are rare as hen´s teeth. So I looked and looked around the German craigs list (Kleinanzeigen) until I found an old Vesta sewing machine for small coin - and told the seller : I just want the bobbin winder but will pay for the whole machine. He agreed as it would save him packaging and it also reduced my shipping costs - actually I did not want to throw the rest of the machine into the scrap. I had to modify the winder as the Vesta bobbins were way longer - plus add a "foot" to the unit which I clamped in a M10 long nut drilled out to 11mm with some set screws to obtain proper height so it can align just right with the drive pulley of the machine - I have yet to mount it to a plate which will be clamped/screwed to the table. Edited 12 hours ago by Tigweldor Quote
