Brand new and never assembled, these 12 tons have been out of stock for almost a year. I reached out to Buckle Guy and they happened to have one tucked away in their warehouse and let it go to me. I'm switching to a Tippman and my space is super tight so I am going to let this 12 ton go. Weaver's heaviest press is 8 tons, this has two adjustable handle heights to deliver the tonage you need. Forewarning though, the handle extension required to deliver the 12 tonnage is quite tall, make sure your space can accommodate it if you do indeed need more than 8 tonnage of press. From Buckle Guy with taxes and freight is probably around $3,800. Save some dollars here and not to mention you can't buy one right now from Buckle Guy if you wanted. They communicated they do not know when this will be back in stock and available.
Asking $3,100
Located in Sacramento, CA.
You must move/bring help to move if local pickup, the head is over 400lbs. I use UShip.com quite often to move bulky and heavy items, will help load on my end if buyer goes that route.
