Contributing Member friquant Posted July 13, 2025 Contributing Member Report Posted July 13, 2025 6 hours ago, FDC said: I'm not sure what you mean by motor pulley, are you referring to the pulley on the servo motor? If so its stock, 45 or 50 mm I think. Yes I mean the pulley on the servo motor. They are typically 75mm. If it has a 15mm cylindrical shaft, that pulley can be replaced with a 45mm pulley for about ten dollars, which will slow down the machine. Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Contributing Member friquant Posted July 13, 2025 Contributing Member Report Posted July 13, 2025 6 hours ago, GerryR said: for future projects, you should consider an AC system with a variable frequency drive (VFD) and a 3 phase inverter rated gearmotor. Can you post links to the pieces one would need to buy in order to build this setup? I'm interested Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members Calidora Posted July 13, 2025 Members Report Posted July 13, 2025 (edited) Wow yours look way better than mine. They are amazing machines. Now that I have mine up and running it makes working on things much easier. I find that post beds are some of the most versatile machine out there. I don't have too much experience with several others but I've used a cylinder bed and flat and I like my post bed much better. Edited July 13, 2025 by Calidora Quote
Members GerryR Posted July 13, 2025 Members Report Posted July 13, 2025 11 hours ago, friquant said: Can you post links to the pieces one would need to buy in order to build this setup? I'm interested Links to AC Drive Components: VFD good for up to 1HP 3-phase motor: https://www.amazon.com/dp/B0DFB57721/?coliid=I8NFU0YE5UPT8&colid=17LBFSFMFWW6H&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it Note: I bought mine through Ebay, but this is the same one. Motor: https://www.bodine-electric.com/products/ac-3-phase-inverter-duty-gearmotors-and-motors/42r-fx-parallel-shaft-ac-3-phase-inverter-duty-gearmotor/ Note: I was able to get model 2263, which has 58 in-lbs. of torque and 340 RPM at 60 Hz. You can choose outputs suitable to your needs and even get right angle output shaft versions. Just for comparison, the DC servomotor I was using was rated at 28.8 in-lbs. Foot Pedal Control: This is where I got a little creative. I took a TIG welder foot pedal and did a little rewiring. I got the unit off of Ebay: https://www.ebay.com/itm/176920994141?_skw=TIG+Welder+foot+pedal&itmmeta=01K01RR8XF07B0ETNHVT3SNZC6&hash=item293150215d:g:7KQAAOSwha9jZI28&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1cdg2dYapN7bLOj7QNBNYvFBgb9nYOw6ivyhEaLfbTDARnhlFmmmIvRE5v%2BmSHS6NHzBxmYRm%2FS%2FOUguxh4QASZ6dKnq4aAfCKcCK9LWjU5OyPxxvNKcH3CjV9WGIL7ylcLvGzb6%2Bdvpe9MAB418aLD72qlvGirmqZ2XNTPpOEnSdadqe%2BJUuU70vTyKzaCPmAPE85JgmuvVu3AwzJYH9iW5vfdQNC7nCE8q1Im3b6Kp6cynjjiIrNBiNTH1T%2Fur%2B7h1JYK8hs%2Bt5hyHSlK4eaNsbSQ%2FRi%2Bmrmp2OVY%2BjRpfg%3D%3D|tkp%3ABk9SR4CP4biAZg I rewired it so the knob-controlled pot limited the top speed so the foot controlled pot had full range to that limited speed. I put everything in a case: https://www.ebay.com/itm/165626696069 These are the basics. I added circuitry for a position sensor that worked off a jog button. I don't use the position sensor, but it is available if I ever want to use it. The jog is so slow that I can stop the needle anywhere I want. This should give you a good start. Feel free to ask any other questions you might have. Happy to help! Quote
Members Scoutmom Posted July 13, 2025 Members Report Posted July 13, 2025 Love the table. Do you mind sharing how you made it and where you got the parts? I see the foot pedal is mentioned above. The machine and speed reducer look great. Quote
Members FDC Posted August 27, 2025 Author Members Report Posted August 27, 2025 For the table I laminated Baltic birch for the core. I cut out the necessary features and tweaked to satisfaction. Then I contact cemented Formica to both sides. I bought the plastic edging on Amazon. I welded up the base with 2" square structural tubing and re-used the pedals and mounting plate from the old table. The casters were also Amazon. A little spray gun work and final assembly. Space is always limited so I wanted a smaller than normal table that was ready to roll. I'm happy with the results and table size. I'm not always happy with project outcomes! Quote
Members FDC Posted August 27, 2025 Author Members Report Posted August 27, 2025 On 7/12/2025 at 9:21 PM, Calidora said: Wow yours look way better than mine. They are amazing machines. Now that I have mine up and running it makes working on things much easier. I find that post beds are some of the most versatile machine out there. I don't have too much experience with several others but I've used a cylinder bed and flat and I like my post bed much better. If it works it's a winner! I just like to start from fresh on some equipment and this Singer certainly deserved the refresh. It is a great machine as you point out! Quote
