Members Zonker62 Posted June 26, 2025 Members Report Posted June 26, 2025 Hello all, I recently purchased this Seiko STW-8B, because of the triple feed, or walking foot, that I need in certain cases (sewing crystal windows on sprayhoods for example). I didn't find any interesting manual like I usually do for Durkopp, Adler, Singer...Seen the ione for the Consew 226RB but no particular procedure for these items. And my maximum stich length at the moment must be something like 2.5-3mm...And I thought it would be nuch more than that. And also the presser foot height, it was set in such manner that the foot wasn't pressing the material (was probably set for some 1/4 inch thickness) and after lowering the bar I barely get 9-10mm (lower than 1/2'). Could anyone help me mainly to set correctly this machine, stitch length and maybe a word or 2 on pressr foot height? Thanks in advance, Cheers! Quote
Contributing Member friquant Posted June 26, 2025 Contributing Member Report Posted June 26, 2025 Perhaps you could post a video of the walking foot in action so we can diagnose Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members Constabulary Posted June 26, 2025 Members Report Posted June 26, 2025 (edited) The Seiko STW-8B basically is a later / more modern clone of the Singer 111G156 with some differences but it basically is a very similar machine. How long is your maximum reverse stitch length? Usually when the reverse stitch is longer the forward is shorter (and vice versa). With other words, usually F & R are equal at approx 5mm at this type of machine (Singer 111 and later clones) so when the F is 3.5mm then usually the R is longer and I guess it is 6.5mm. Edited June 26, 2025 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Zonker62 Posted June 27, 2025 Author Members Report Posted June 27, 2025 Hi! Thanks for the replies. F&R are exactly the same and there's a beautiful reverse giong in its path. I will post a video so you can see and diagnose but I was looking for something written, 'cause both Seiko/Consew manuals are scarce on the tuning... Quote
Members Constabulary Posted June 27, 2025 Members Report Posted June 27, 2025 The Juki 562 / 563 manual is probably the closest for your SEIKO STW8. See attachment. Can you post pictures from the underside of your machine maybe the stitch length has been limited for what ever reason. Juki 563 562 Manual.pdf Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
