Members SUP Posted July 4 Members Report Posted July 4 I have some beautiful pirarucu pieces and am not sure how to use it. The scales are removed and the scale bases remain, in quadrilateral shapes. These shapes have a ridge around them. The ridges are not firm. They are almost filamentous. You can reach under them, to where the scalers were inserted - tiny pockets, as it were. The ridges can tear off easily if I make anything with the leather as it is now. I have seen pirarucu boots and the scale bases and ridges seem pretty firmly in place. If they were not, they would not last long. How do they reach that stage? I have tried Resolene but that gives too much of a shine and does not stick anything in place. Glue maybe, but sticking each scale base in place is going to be tie consuming, not to speak of the damage to the appearance of the leather. I tried that too though. I have heard suggestions of shellac but that will destroy the texture. If anyone has worked with Pirarucu and can guide me on how to use this beautiful, unusual leather, I would appreciate it. Incidentally, Arapaima is a food source in South America and increasingly, being farmed ethically. Quote Learning is a life-long journey.
Members SUP Posted July 4 Author Members Report Posted July 4 It appears that not many have experience working with Pirarucu. When I learn about it, I will post it here for others who might want to know about it as well. Quote Learning is a life-long journey.
Members SUP Posted Monday at 10:10 PM Author Members Report Posted Monday at 10:10 PM I have discovered that the conditioner from Chemical Guys and Resolene works. I apply the conditioner, including under the scale areas. I allow it to dry for 4-5 hours. Then I apply a layer of Resolene in the same way and allow it to dry for a day. A thin layer of Resolene though. The result is a leather that glows softly and is less vulnerable to damage. Hope this information helps anyone else who is working on Pirarucu. If anyone else has better ideas, do share. Quote Learning is a life-long journey.
