Members Happycow Posted July 14 Members Report Posted July 14 I'm sewing canvas and leather bags. Which is best for the job? Quote
Moderator Wizcrafts Posted July 14 Moderator Report Posted July 14 1 hour ago, Happycow said: I'm sewing canvas and leather bags. Which is best for the job? I'm not familiar with either machine. But, I googled both and found that the main difference is that the Seiko is a compound feed walking foot machine, while the Consew is merely a needle feed machine. The walking foot would have an advantage if you have to sew over new layers and tall seams. Its compound feed will simply walk up and down over these changes in layers. The needle feed machine will stop against a new layer unless it is very thin. Both machines are double neelde machines. You'll need to learn how to turn corners properly and balance the knots with two tensioners and bobbin tension springs. Both use large bobbins. In some instances, time is money. If your sewing is based on an hourly charge, the needle feed machine will probably spin faster and run smoother. There was a discussion about the Seiko in 2016, here: Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Happycow Posted July 18 Author Members Report Posted July 18 Thanks for that insight. Much appreciated Quote
