Members StitchDoc Posted July 31 Members Report Posted July 31 I'm trying to find a roller foot for a Singer 44-10. I bought one on Amazon but the arm the roller is attached to is too long and I'm not able to move it into position. Any help is appreciated. Thanks! Quote
kgg Posted July 31 Report Posted July 31 34 minutes ago, StitchDoc said: I'm trying to find a roller foot for a Singer 44-10. Would these work???? kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members StitchDoc Posted August 1 Author Members Report Posted August 1 Maybe. this is the one I bought that is "too long". The arm from center of screw to center of screw is 1.5 in. The shank length on the machine is 1" Here's a pic of what I bought (that doesn't fit): I think a 1/4 in shorter would work Quote
kgg Posted August 1 Report Posted August 1 12 hours ago, StitchDoc said: Maybe. this is the one I bought that is "too long". The arm from center of screw to center of screw is 1.5 in. I have two types: A) with a large wheel: the dimension according to my mic. Large Wheel: a) Center of screw to center of screw on arm is 1.435" ( 1 - 53/128", 35.9mm). b) Wheel Diameter is 1.236" ( 1 - 15/64", 31.4mm) Small Wheel: a) Center of screw to center of screw on arm is 1.435" ( 1 - 53/128", 35.9mm). b) Wheel Diameter is .8745" ( 7/8", 22.21mm) 12 hours ago, StitchDoc said: I think a 1/4 in shorter would work Body is the same, length is the same just the wheels are different diameters. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members StitchDoc Posted August 1 Author Members Report Posted August 1 I thought I sent the following reply from my phone but, I don’t see it here so I’ll write it again: I found a video online of a gentleman (in the UK I believe) that was doing the same thing as I am on a similar machine. What I learned was there is a way to change the height of the shaft that the foot mounts to, that then allows the user to properly position the roller foot. Thanks for replying but, I think I’m all set. Regards….. Quote
