Members speedybri Posted September 6 Members Report Posted September 6 Hello. I picked up a landis three a few days ago. It's running good however it keeps lifting the leather. I've tried adjusting the feeder foot pressure. I'm sewing 3 layers of 12/13oz together. Making lead harness traces. So it's pretty heavy. Does anyone know what might be causing the lifting and how to correct it? Thank you for any and all help. Quote
Moderator Wizcrafts Posted September 6 Moderator Report Posted September 6 @speedybri This sounds like a case of the leather is too dry and dense. Is it the awl or the needle that is getting stuck and lifting the stack of leather? If it's the awl, you may need to oil the leather to soften it a little. Or, run the thread through liquid stitching wax or silicon in the wax pot. If it's the needle, either move down one needle size or move up one awl size. And, add more foot pressure until you figure out the real problem. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members speedybri Posted September 6 Author Members Report Posted September 6 7 hours ago, Wizcrafts said: @speedybri This sounds like a case of the leather is too dry and dense. Is it the awl or the needle that is getting stuck and lifting the stack of leather? If it's the awl, you may need to oil the leather to soften it a little. Or, run the thread through liquid stitching wax or silicon in the wax pot. If it's the needle, either move down one needle size or move up one awl size. And, add more foot pressure until you figure out the real problem. Thank you! That's a huge help. I do have liquid wax running through the wax pot and I'm also waxing the thread on the bobbin. I might try putting a bit of silicone on the awl itself. See if that helps. But I'll definetly try switching around the needle and awl sizes to see if that helps. And tightening down the presser foot too. Thank you! Quote
