Guest el_pepou Posted September 10, 2025 Report Posted September 10, 2025 Hi, I recently bought two cans oil advertised as pure neatsfoot oil. However, I have worked with neatsfoot oil from other brands before and this one seems different in multiple ways. I had used starwax neatsfoot oil, wich was odorless, and stayed liquid even at about 10 degrees celcius, and saphir brand, wich had a bit of a smell but not a suspicious one and remained liquid too. The oil I just bought is supposedly from a brand called P.Paulin, and not only does it have a very strong rancid smell, it does not stay liquid under Id say 20 degrees celcius. It is also cloudy while the other brands were transparent. is this normal? is it just a different neatsfoot oil? or is it neatsfoot oil mixed with a great deal of tallow and such greases? I dare not use it on any piece of leather, or even to lube machinery because of this horrid stench. did I get scammed? or did I just observe non-industrial neatsfoot oil for the first time? Quote
Members Cumberland Highpower Posted October 28, 2025 Members Report Posted October 28, 2025 (edited) Sounds like allot of the neatsfoot oil I've used. I remember everyone swearing by "Sheps" here in the USA. It was identical to what you describe, stench and all. I used a fair amount over some years. If you heat it up it will loose the cloudiness. Don't use it to lube machinery, it's not suitable for such use unless you're in a Post Apocalypse Zombie-Walking World. (I guess would be ok at that point). Edited October 28, 2025 by Cumberland Highpower Quote
Members NerdyLeather Posted December 3, 2025 Members Report Posted December 3, 2025 Some batches of pure neatsfoot can smell pretty rough, especially if it’s closer to the old style stuff that isn’t overly filtered. Cloudiness and thickening in cooler temps can happen too, since real neatsfoot isn’t always perfectly clear or stable like the more refined brands. That said, what you’re describing sounds stronger than normal. Most leatherworkers avoid anything with a heavy rancid odor because it usually means oxidation or mixed fats. I wouldn’t put it on good leather either. You probably didn’t get scammed on purpose, but it might be a low grade or poorly stored product. I’d stick with the brands you’ve had good results with and keep this one away from your projects. Quote
You are posting as a guest. If you have an account, sign in now to post with your account.
