Members Gufnstuf Posted 4 hours ago Members Report Posted 4 hours ago Hello all, this forum helped greatly in helping me identify the machine that I wanted and most anything I needed to know. however, I have one issue that I can’t seem to find the answer to. my machine sews pretty well, and I have outfitted it with a consew servo motor and eps. Works awesome. the question I have is that when my needle comes to the peak of the up stroke, my bobbin thread is still hooked. I have to advance the hand wheel 20-25 degrees before the thread releases to pull out so I can cut it. I have checked the timing from the hand wheel to the bobbin shaft as shown in the manual and it’s dead on. its a minor inconvenience but the needle has already started dropping by the time the thread releases and seems wrong. Maybe that is just how these machines are, but if it’s not I want to fix it. thanks for any guidance. Quote
Contributing Member friquant Posted 3 hours ago Contributing Member Report Posted 3 hours ago Trust the machine. (not the motor haha) To understand when is an appropriate time in the stitch cycle to pull your material free, you can stitch slowly (handwheel!) with the bobbin cover removed. I both start and end my seams with the takeup lever at the top of the stroke. Depending on which model of digital servo motor you have, there may be adjustment within the menu to configure how much rotation happens between what the servo considers Needle UP vs Needle Down. I suppose in my wildest dreams a needle positioner might default stop for needle down a little after the hook point grabs the thread. Then when I heel tap it would first rotate to where the takeup lever is at its highest point (to lock the last stitch), then reverse ten or twenty degrees and come to a stop when the needle is at its highest position so it's easy to pull the material out. ☺️ Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
AlZilla Posted 3 hours ago Report Posted 3 hours ago Exactly, just tweak the stopping point until it stops with the tension arm all the way up. I'd have to go sit down in front of a machine, but it should be pretty close to the moment the needle is all the way up. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
