Members shoestareve Posted September 17, 2025 Members Report Posted September 17, 2025 (edited) Hello everyone, I’m new here from South Korea, and I’m facing a big problem with redyeing my custom-made dress shoes. I hope someone can help me figure it out. I bought these dark brown (actually closer to medium brown) shoes two years ago, along with other pairs in black and light brown. Compared to the others, this pair of dark brown shoes seems to have some sort of transparent coating or sealant, like Resolene or Saddle-Lac. Still, I was able to polish them Unfortunately, last year the right toe got scratched. I used sandpaper to smooth out the surface, thinking I could restore it by applying Saphir Shoe Cream (Crème Surfine, Color 05: Dark Brown) and later by wax to make them mirror shine. The surface became smooth again, but the shoe cream didn’t cover the scratch or recreate the coating anymore. When I applied Saphir Renovating Cream (Crème Rénovatrice, Color 05: Dark Brown), it just looked like paint sitting on the surface instead of blending into the leather. After polishing a few times, it simply came off. So, I tried acetone to deglaze the shoes and remove the original finish, planning to redye them dark brown. I used Fiebing’s Pro Dye, applying three coats with one-hour intervals by brushing, allowing it to penetrate Afterward, I left the shoes to dry for 24 hours in front of a fan. I buffed them with a white cloth for 10-15minutes and they seemed fine. Then I applied Saphir Renovateur Cream (Conditioner), hoping to polish them well after coniditioning them. The photo below shows the shoes after dyeing. I am indeed quite satisfied because it looks great. But here coms the problem: when I buffed the newly dyed shoes with a dry or damp cloth, they were fine. But whenever I applied any type of cream (Ex: Renovateur, Crème Universelle Leather Balm, colored shoe cream, etc.) or wax (Ex: Saphir Pâte de Luxe) with water, there's huge ruboff: the dye bled heavily and even reverted to the condition before dyeing. That means I couldn’t polish do coating on them by waxat all. I ended up removing the dye completely with acetone again, which took a lot of time. Interestingly, even after deglazing, the leather surface was still very smooth, almost as if dye couldn’t penetrate it properly. I ran a small test by applying just Saphir Shoe Cream and letting it dry. But again, whenever I applied any cream product, the dye bled. This was unseen on any other shoes I have. I've been extremely frustrated and trying to figure out the root cause but without success. Should I simply wait longer (2–3 days) after dyeing? Or should I apply something like oil or water to the shoes before dyeing? Or with this type of leather, does it require any special treatment before dyeing? Or would it be necessary to apply sealer such as leather sheen or Resolene on shoes? I originally wanted to ask the shoe company, but unfortunately, they are no longer in business. I’d really appreciate it if someone could point out what I’m doing wrong or give me some advice. Thanks a lot! Edited September 17, 2025 by shoestareve Quote
kgg Posted September 17, 2025 Report Posted September 17, 2025 40 minutes ago, shoestareve said: I’d really appreciate it if someone could point out what I’m doing wrong or give me some advice. Here is a link to my experience with re-dying shoes. It may help, maybe not but it may give you some ideas. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Tove09Tilda Posted September 17, 2025 Members Report Posted September 17, 2025 (edited) Hey, I have no experience with shoes - so much said from the start, but I dye my dog collars myself most of the time. One thing I noticed there is that If you don't put a sealer on top, you have rub off as soon as you clean / condition. A conditioner is not a sealer to my knowledge. So you might need to have a look into that. I know that a lot of "shoepeople" use the angelus sealers. I use them as well and have noticed, that these sealers tend to flake a bit in the application process within cracks and creases, but that could also have been because I used up a bottle and those were the last drops. With the angelus ones I can tell you, that a small bottle lasts you a bit of time. My recommendation would be to try the caranauba creme by Fiebrings as it can also be used in the restoration process and as a finish, plus it builds a scratch resistant coate or after you striped your shoes from all your prior-finishing attempts the high-gloss finish by angelus. Was just a quick thought when I read through your problem, as I had a predyed leather strap on my table that bled a lot in the care process, when I was done stitching and seemed to not have a finish/seal on top. I fixed it by removing my care products, applying some neatsfoot oil, waiting for it to soak in and then finished it with the high-gloss. So far the colour is still vibrant and is not bleeding anymore, when being cleaned. Same applies to all my dog collars, that I dyed myself and used the finish as a last step. -Tove Edited September 17, 2025 by Tove09Tilda Quote
Members shoestareve Posted September 18, 2025 Author Members Report Posted September 18, 2025 (edited) Below is the photo which is mistakenlly pulled down. It was after I deglaze the shoes thorugh acetone. Edited September 18, 2025 by shoestareve Quote
Members shoestareve Posted September 18, 2025 Author Members Report Posted September 18, 2025 10 hours ago, kgg said: Here is a link to my experience with re-dying shoes. It may help, maybe not but it may give you some ideas. kgg Thank you kgg! These are fantastic works Quote
Members shoestareve Posted September 18, 2025 Author Members Report Posted September 18, 2025 9 hours ago, Tove09Tilda said: Hey, I have no experience with shoes - so much said from the start, but I dye my dog collars myself most of the time. One thing I noticed there is that If you don't put a sealer on top, you have rub off as soon as you clean / condition. A conditioner is not a sealer to my knowledge. So you might need to have a look into that. I know that a lot of "shoepeople" use the angelus sealers. I use them as well and have noticed, that these sealers tend to flake a bit in the application process within cracks and creases, but that could also have been because I used up a bottle and those were the last drops. With the angelus ones I can tell you, that a small bottle lasts you a bit of time. My recommendation would be to try the caranauba creme by Fiebrings as it can also be used in the restoration process and as a finish, plus it builds a scratch resistant coate or after you striped your shoes from all your prior-finishing attempts the high-gloss finish by angelus. Was just a quick thought when I read through your problem, as I had a predyed leather strap on my table that bled a lot in the care process, when I was done stitching and seemed to not have a finish/seal on top. I fixed it by removing my care products, applying some neatsfoot oil, waiting for it to soak in and then finished it with the high-gloss. So far the colour is still vibrant and is not bleeding anymore, when being cleaned. Same applies to all my dog collars, that I dyed myself and used the finish as a last step. -Tove Hello, Tove! Thanks for your advie! Yes, I didn’t apply any sealer to the shoes, since many YouTubers in their videos just use conditioners after re-dyeing their shoes. They then create a gloss or mirror shine, which looks like a coating or sealing effect. So I did the same, but I didn’t realize it would turn into a disaster. I've just looked up that Fiebing's Caranauba Creme which you've mentioned but fortunately it's not sold in Korea. I think I might put Fiebing's Leather Sheen or Resolene on my shoes after I re-dye them again Also I've seen many people talking about using neatsfoot oil, let me look into whether this is also suitable for sealing my leather shoes, or if it will play more of a conditioner role for them. Quote
kgg Posted September 18, 2025 Report Posted September 18, 2025 2 hours ago, shoestareve said: Also I've seen many people talking about using neatsfoot oil, let me look into whether this is also suitable for sealing my leather shoes, or if it will play more of a conditioner role for them. Some AI notes on Jojoba oil and Neatsfoot oil. Jojoba oil is chemically nearly identical to the sperm whale. Jojoba oil is a liquid wax ester that closely resembles human sebum. It penetrates leather fibers well, moisturizes deeply, and is less likely to darken leather or cause discoloration. It is also stable, won't go rancid, and is hypoallergenic. It is often recommended for delicate leather items and is favored for leaving a natural feel without heavy saturation. However, it is more expensive and can be harder to apply evenly without over-saturating the leather. Neatsfoot oil is derived from cattle bones and is a traditional, widely used conditioner for rugged and outdoor leather items like boots and saddles. It penetrates deeply and restores suppleness and flexibility to leather. However, it can darken leather significantly and may turn rancid if over-applied, which can negatively affect the leather and its stitching over time. It is suitable for thicker, durable leathers but needs cautious use. Neatsfoot oil is still commonly used for leather boots, saddles, and outdoor gear. It deeply conditions but may soften or darken lighter leathers over time and must be used in moderation to prevent damage to stitching. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
