Moderator bruce johnson Posted September 29, 2025 Moderator Report Posted September 29, 2025 Part of the process of tanning is adding back oils/fats and one of the treatments is called fat-liquor. From what I read - not a single substance but various sorts of sulfonated oils depending on tannery. I was told years ago that sulfonated neatsfoot oil was one of them - one of the major ingredients in Lexol leather conditioner. The reason that the historic casing mix recipe I was given contains Lexol conditioner. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members ThisIsMyFirstRodeo Posted September 30, 2025 Author Members Report Posted September 30, 2025 On 9/29/2025 at 4:15 AM, kgg said: I have seen something similar while wet forming on some hides not all, cost effective 2/3 and 4/5 oz veg tan leather and not from Tandy. It has appeared as dots or small lines. I figured it was fat appearing but this topic caused me to do an AI search related to the Tandy Econo and probably applies to other suppliers the results were: i) "The milky substance rising from Tandy's Econo Veg Tan leather while casing is likely natural oils and tannins leaching out of the leather as it deeply hydrates. Casing involves thoroughly wetting the vegetable-tanned leather so the water penetrates evenly through the fibers, which can draw out waxes, fats, and residual tanning materials causing a cloudy or milky appearance on the surface. This is more common in economy grades like Econo Veg Tan because they may have more natural variations and less refined finishing compared to higher-grade leathers." ii) The regions most commonly associated with these Econo vegetable-tanned hides are South America—especially Brazil and surrounding countries—and in some cases Asia, depending on availability and market supply. These regions are major global suppliers of cattle hides used in mass-market leather production, which matches Tandy's focus on affordable, large-batch material for their Econo line. @chuck123wapati I agree Not helpful. Could have been worded a little differently. kgg And there is the answer to my question! Thank you KGG, I doubt I would have found the answer on my own. — AZR Quote
Members ThisIsMyFirstRodeo Posted October 1, 2025 Author Members Report Posted October 1, 2025 (edited) On 9/28/2025 at 2:14 PM, chuck123wapati said: What did you clean it for, and what did you clean it with? its probably the soap. Chuck, returning to your question, I use warm water and dawn dish soap beforehand. I figure if it’ll get crude oil off of a duck, then it’ll get whatever oils that come to the surface without damaging the hide, then rinsed as many times with warm water as needed, and once more for good measure. Because it’s usually fully-saturated by then, I let it air dry for several hours (AZ, it’s a dry heat, etc.) And I do have logic regarding dawn, albeit it may be flawed logic… It pulls the oils out, leaving it thirsty, which then will pull the oils from the dye deeper into the hide (almost exclusively use Fiebing’s Pro). But again, my logic could very well be flawed. With finished leather, then I use saddle soap. Only exception I can think of is my couch. Then I use dawn if I absolutely have to, followed by saddle soap. So far, it’s worked well for me, but if you have a different process, then I’m all ears. — AZR Edited October 1, 2025 by ThisIsMyFirstRodeo Quote
