Members Zonker62 Posted 20 hours ago Author Members Report Posted 20 hours ago The thread comes out of the slit, goes around the bobbin until approximately facing the needle (1/4 turn), and then the tension is so high of course, that either upper thread breaks, either I catch it in time and reinsert the thread into the slit..until next time... Will provide pictures... Quote
Moderator Wizcrafts Posted 11 hours ago Moderator Report Posted 11 hours ago @Zonker62 I always load my bobbins so they unload against the direction of the slit under the tension spring. That sharp turn adds some tension but helps keep the thread under the spring. If your bobbin suffers from run-on rotation, get an "anti-backlash spring." Some are round and some are star shaped. They simply drop in under the bobbin and hold onto it as the shuttle spins. They bring the bobbin to a better halt when you stop and start rapidly. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Zonker62 Posted 9 hours ago Author Members Report Posted 9 hours ago Thanks! that's a great idea, and it comes exactly where I thought where the problem was, a run-on or overrotation after a brutal stop which makes some lack... I'll check where this is available!Thanks a lot! Now with all this, on the STW-8B, we have lost the Mitsubishi DU-105 subject...:-) Edit: "Some slack": Quote
