hello
recently I re-timed my Juki LU- 563 hook, after which the bobbin area began to make a grinding sound. Does anyone know what it might be?
Here is a video of the sound:
IMG_1297.MOV
any help/advice would be appreciated.
Try listening as you handwheel the machine. It kind of sounds like gears are grinding from being too close together.
I might also be the opener arm pulling the shuttle all the way back with a hard stop. There must be a little clearance when the arm pulls the tab back.
Posted IMHO, by Wiz
Thank you for the advice Wizcrafts. The sounds still persist even with the case opener off so I might try fiddling with the gears more.
I second Wiz' suggestion to turn the handwheel by hand for infestigation. If you can't isolate the cause, remove the timing belt. Then you can move the hand wheel (and arm shaft and needle bar) independently of the hook shaft.
Also check if there is anything else contacting the face of those bevel/timing gears. On my Jianglong 341, the first time I moved the hook saddle to the left (to adjust hook to needle distance) left me with the bevel gears to rubbing on the feed dog eccentric. Once I also moved the feed dog eccentric to the left a bit, it was happy again.
friquant. Like a frequent, piquant flyer.
Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Thanks Friquant, I'm pretty sure the machine sews ok but the sound raises some concern as it only started after I re timed the hook. Also removing the timing belt is a good tip I wish I thought of when trying to find where the sound was coming from. I think it might be coming from the large timing gear and the small gear on the hook saddle although nothing I do seems to fix the sound (I've tried re timing and moving the big gear to mesh with the smaller one differently  a few times to see if that fixes anything but the sound still persists) but I will try messing with the feed dog eccentric as well. I only just got this machine a couple months ago and am pretty new to sewing in general so both you and  wizcrafts advice has been really helpful.
Edited by kamo48399
Does the grinding sound happen when you turn the hand wheel by hand?
What if you separate the bevel gears slightly?
Uwe said in a video once that if you don't match up the teeth when you move a hook saddle the gears will be loud. To me yours sounds more like a grind than I would expect from gear teeth bedding in on new neighbors.
Yeah the grinding sound still happens by hand. I tried separating the gears and every time I tighten the screws the sound still persists. would you be able to send the the video where Uwe says that or is it in the hook timing video?
Edited by kamo48399
Here is the comment that contains the video:
https://leatherworker.net/forum/topic/36127-pfaff-545-safety-clutch-and-timing/page/2/#findComment-442262
It's the video that Adler 67 GK 373. Don't remember how far through
3 hours ago, kamo48399 said:
here is a video of me hand turning the wheel and the sound that it makes
You might try sliding the gear on the hook driving shaft all the way left (so it no longer drives the hook). Then see if it still makes noise when you move the hand wheel. That will tell you if it's hook related or not.
While the gear is out of the way, also try rotating the hook by hand and check for noise there.
Before all that: if your teeth are still matched up as from the factory, I suggest marking them before sliding the gear out so you can but them back in the same place.
