MikeG Posted yesterday at 05:17 PM Report Posted yesterday at 05:17 PM Juki LU-563 135X16X19 needle Tex 135 bonded nylon 3 layers of 3oz veg tan (less than 1/4" total) Stitching forward gives a good result top and bottom (left side in pictures) -- when reversed (right side in pictures), the top looks OK, but the bottom has loops as though the top tension is too loose. Any thoughts where to look to correct this issue? Thanks, all! Quote
Members photonashville Posted 23 hours ago Members Report Posted 23 hours ago Perhaps go up in needle size to 20, 21 or 22 to see if that corrects it. That's all I can suggest. Quote Pfaff 1245, Pfaff 195, Consew 226R-1, restoring a pre-1940s Singer 112W115
kgg Posted 23 hours ago Report Posted 23 hours ago 1 hour ago, MikeG said: Juki LU-563 135X16X19 needle Tex 135 bonded nylon 3 layers of 3oz veg tan (less than 1/4" total) The number 19 needle is to small for Tex 135 thread. In thin you need a #22, medium a #23 and thick #24. Here is a good needle to thread reference chart ( https://www.tolindsewmach.com/thread-chart.html ) kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
MikeG Posted 22 hours ago Author Report Posted 22 hours ago Genius! A larger needle solved the problem, even though I don't understand why it only happened in reverse. I will take the win! Thanks!!!! Quote
Contributing Member friquant Posted 21 hours ago Contributing Member Report Posted 21 hours ago 3 hours ago, MikeG said: Stitching forward gives a good result top and bottom (left side in pictures) -- when reversed (right side in pictures), the top looks OK, but the bottom has loops as though the top tension is too loose. This may help: https://leatherworker.net/forum/topic/101339-problem-with-reverse-stitch-tightness-on-singer-industrial/#findComment-685135 Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
