Members LMP Posted Tuesday at 07:42 PM Members Report Posted Tuesday at 07:42 PM Hi all, I just acquired a Singer IIIw155, and went online to get the parts manual, and found two. While most of the part numbers are the same, there are many with different part numbers. I get when there is a different letter at the end, maybe for different metal compounds used, but many have very different numbers. I made a pdf of the plates side by side. I started to highlight in pink all the part numbers that are different in the two manuals, but got tired of doing so after 5 pages. But, you can get the idea. I'm wondering if there is anything different. I tried to research if two parts (seemingly identical but with two different numbers) are inter-changeable, and apparently chatgpt thinks they are distinct parts with different functions. If you can, please see the pdf. I'd love to find out from which set of part numbers I should order and if there really is any difference. Also, I don't know what is in my existing machine, so not sure if I should worry about compatibility. Thanks! side by side of two different parts lists.pdf Quote
Members LMP Posted Tuesday at 10:13 PM Author Members Report Posted Tuesday at 10:13 PM I meant to type Singer IIIw155, not iiiw155. Thanks. Quote
Members Constabulary Posted Tuesday at 10:47 PM Members Report Posted Tuesday at 10:47 PM its actually 111w155 - I doubt there is a mechanical difference, maybe its a different plating on the metal parts (chrome vs nickel or vs blueing or something) either of the parts will work, I´m very sure about that. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members LMP Posted Wednesday at 01:49 AM Author Members Report Posted Wednesday at 01:49 AM 3 hours ago, Constabulary said: its actually 111w155 - I doubt there is a mechanical difference, maybe its a different plating on the metal parts (chrome vs nickel or vs blueing or something) either of the parts will work, I´m very sure about that. ah, yes. 111. I meant to type that in my correction. Anyhow, thank you. Quote
