Members johnatl Posted July 30, 2016 Members Report Posted July 30, 2016 Thank you Wiz. saving this in a file! Needles? Would I use needles that the thread fits as described by Singermania typically? I do appreciate the help. Quote
Members Sticks Posted November 13, 2016 Members Report Posted November 13, 2016 (edited) Can someone tell me the best needle for the Seiko STW-8B ? The person I bought the machine from told me to use 17/231 needles. However google told me 135/17 or 16 for leather. Im a bit bit confused . Ill be mainly using bonded nylon 40s (#69). Also I only seem to be able to find 16/231 not 17. thnx Edited November 13, 2016 by Sticks Quote
Members Sticks Posted November 13, 2016 Members Report Posted November 13, 2016 ok I guess its 135/17.. Quote
Moderator Wizcrafts Posted November 13, 2016 Moderator Report Posted November 13, 2016 7 hours ago, Sticks said: Can someone tell me the best needle for the Seiko STW-8B ? The person I bought the machine from told me to use 17/231 needles. However google told me 135/17 or 16 for leather. Im a bit bit confused . Ill be mainly using bonded nylon 40s (#69). Also I only seem to be able to find 16/231 not 17. thnx Needle System 135x17 (round) or 135x16 (leather) Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Sticks Posted November 13, 2016 Members Report Posted November 13, 2016 40 minutes ago, Wizcrafts said: Needle System 135x17 (round) or 135x16 (leather) Ok, thnx. Quote
Members Hali Posted December 19, 2022 Members Report Posted December 19, 2022 I have a query regarding the general guidelines for working with specific weight yarns on needles. I have a gauge for the needle size that also indicates the proper weight of yarn to use with those needles. What if you had larger or smaller needles, I wonder? For instance, I have a pattern that calls for size 8 needles, but my light-weight yarn suggests using a size 5 or 6. If I use heavier needles and lighter yarn, how will it affect the stitch? What if I used smaller needles and thicker weight yarn instead? Quote
Moderator Wizcrafts Posted December 19, 2022 Moderator Report Posted December 19, 2022 9 hours ago, Hali said: I have a query regarding the general guidelines for working with specific weight yarns on needles. I have a gauge for the needle size that also indicates the proper weight of yarn to use with those needles. What if you had larger or smaller needles, I wonder? For instance, I have a pattern that calls for size 8 needles, but my light-weight yarn suggests using a size 5 or 6. If I use heavier needles and lighter yarn, how will it affect the stitch? What if I used smaller needles and thicker weight yarn instead? When you say "yarn" do you mean the fluffy soft stuff, or smooth thread? Your use of "yarn" suggests that you are not into industrial leather sewing machines (yet). We usually deal with "thread" that is bonded together and lubricated to withstand the friction and heat generated when sewing leather. I think of yarn as something one would use in a sweater. Further, most of our needles start at a #16 or 18 and go UP from there. I don't even possess a #8 needle for my one straight stitch machine. What make and model sewing machine are you using that uses a #8 needle? What is the brand of the "yarn" you want to use? A small photo of the bottom of a spool would help. Take the photo at as small a resolution as possible to be within our upload limits. As a guideline, no matter what type of thread you want to use, it must slide through the eye of the needle. If you also have a bobbin in the machine, the needle must poke a big enough hole to pull up two threads that overlap into a knot. So, if a needle is already tight when you test it with just one thread, it probably will be too small to pull up both threads and their knots.It also depends on the density and thickness of the sewn material. It is easier to pull up knots in soft linings and broad cloth than in nylon, denim, vinyl and leather. Just use a bigger needle if you see knots on the bottom despite making tension adjustments! Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Hali Posted December 20, 2022 Members Report Posted December 20, 2022 11 hours ago, Wizcrafts said: When you say "yarn" do you mean the fluffy soft stuff, or smooth thread? Your use of "yarn" suggests that you are not into industrial leather sewing machines (yet). We usually deal with "thread" that is bonded together and lubricated to withstand the friction and heat generated when sewing leather. I think of yarn as something one would use in a sweater. Further, most of our needles start at a #16 or 18 and go UP from there. I don't even possess a #8 needle for my one straight stitch machine. What make and model sewing machine are you using that uses a #8 needle? What is the brand of the "yarn" you want to use? A small photo of the bottom of a spool would help. Take the photo at as small a resolution as possible to be within our upload limits. As a guideline, no matter what type of thread you want to use, it must slide through the eye of the needle. If you also have a bobbin in the machine, the needle must poke a big enough hole to pull up two threads that overlap into a knot. So, if a needle is already tight when you test it with just one thread, it probably will be too small to pull up both threads and their knots.It also depends on the density and thickness of the sewn material. It is easier to pull up knots in soft linings and broad cloth than in nylon, denim, vinyl and leather. Just use a bigger needle if you see knots on the bottom despite making tension adjustments! Got it, got it.. Thankyou so very much ! Quote
Members brushew93 Posted February 14, 2024 Members Report Posted February 14, 2024 On 12/19/2022 at 10:28 AM, Wizcrafts said: When you say "yarn" do you mean the fluffy soft stuff, or smooth thread? Your use of "yarn" suggests that you are not into industrial leather sewing machines (yet). We usually deal with "thread" that is bonded together and lubricated to withstand the friction and heat generated when sewing leather. I think of yarn as something one would use in a sweater. Further, most of our needles start at a #16 or 18 and go UP from there. I don't even possess a #8 needle for my one straight stitch machine. What make and model sewing machine are you using that uses a #8 needle? What is the brand of the "yarn" you want to use? A small photo of the bottom of a spool would help. Take the photo at as small a resolution as possible to be within our upload limits. As a guideline, no matter what type of thread you want to use, it must slide through the eye of the needle. If you also have a bobbin in the machine, the needle must poke a big enough hole to pull up two threads that overlap into a knot. So, if a needle is already tight when you test it with just one thread, it probably will be too small to pull up both threads and their knots.It also depends on the density and thickness of the sewn material. It is easier to pull up knots in soft linings and broad cloth than in nylon, denim, vinyl and leather. Just use a bigger needle if you see knots on the bottom despite making tension adjustments! Your last paragraph was a complete “AH-HA” moment for me. I’ve never seen it explained that way but now it makes complete sense. Thank you!! Quote
