I learned a great burnishing technique from a saddlemaker I worked for. Cut a square of canvas (or "Duck Cloth" as the fabric stores call it) about 14" to 24" square. Smaller would work too. Use yellow paste saddle soap (the white paste will discolor the leather, don't ask me how I know!) and rub it in until the canvas is saturated. Let it dry. To slick the edge, wet the leather if you want, but I usually just spray a bit of water directly onto the folded canvas rag. I fold it up to make it more managable. Then rub the damp (Not wet, just enough to reactivate the soap) on the edge of the leather. I usually wait until all finish work is done, but since it's saddle soap it won't resist the finish. When the edge dries it should be nice and slick. Normally drying only takes a couple minutes. After the finishing and edge coloring (I use a sharpie marker) is done I rub with wax, paraffin or bees wax, and shine that with a dry canvas cloth. This melts the wax a bit and really makes a fancy edge finish that will hold up. You could also coat with edge kote, a clear finish i.e. sheen, or whatever rather than use the wax.
BTW, waxing the edges is the only way I know of to get a slick edge on chrome tan or latigo. It works really well on Harness leather too.
Dave T.
I have made my own burnishing tool simular to the one above but I use a piece of hard fir on a shaft mounted between 2 bearing blocks from princess auto. with a pully at the end to the motor I can choose the speed with the pully size . I started out wit a square 3x3 and used my setup as a lathe with a wood plane to turn it round, then filed in with a couple of round files 3/8 deep grooves to facilitate the various thicknesses of leather so as to finish the round edge as well.
I just recently added a strip of leather to one section as a power strop
Cost:
Motor free
wood free
rod and bearings about $20.00
It looks like your motor is a starter off of a car. Is it? I mean... I could hit up a junk yard for one of those. I could use an old car battery as the power supply, with a heavy duty switch to turn it on and off. My battery charger would work fine to keep the battery topped off when it gets low on juice. Seems like an easy build to me.
- "Kilted" Jim Warren
Jim
The motor is just a small freebee 110 volt ac motor
Leather work for the fun of it
http://www.stolpsaddles.com
Jim
Thanks. I'll have to have the wife watch freecycle for an old vacuum that has a good motor.
Thanks to everyone for the input!
I know I have posted this before, cause I am a true believer, but even with out the tool it is interesting to watch.
I bought one of these thinking it would speed things up and make some of the production items go a little faster but it does not do as nice of an edge as I can do with some water and a piece of canvas. Thinking about selling it.
Randy
Randy Cornelius
Cornelius Saddlery
LaCygne, Kansas
Randy & Riley Cornelius
Ride Hard, Shoot Fast and Always Tell the Truth...
I have one and it works great. Highly recommended especially for production type work where speed is important. Or even just lazy folks who don't want to spend a lot of time or elbow grease burnishing.
:red_bandana::red_bandana::red_bandana:
Ride Safe!
Bree
2003 Dyna Wide Glide
Memberships:
Iron Butt Association, Niagara Falls HOG, Wild Fire HOG
NRA, Niagara County Sportsman's Association
  • 1 year later...
Yes, spit works better because of the properties in your saliva. Then burnish with a good a piece of canvass.
It's true. I've read elsewhere on these forums that burnishing can be done with some spit and a dowel rod. So I tried it on a couple items. Looked really nice... until about 24 hours later when it looked like I had done nothing at all.
Am I doing something wrong? Have I missed a step? Is there some sort of prep work involved besides rubbing copius amounts of saliva on the edge and rubbing it to that "burned" stage with the dowel? I'm at wits end with this one!
