Members megabit Posted March 10, 2009 Members Report Posted March 10, 2009 Lippy said: Rgerbitz,This may be a stupid question, but why the diagonal cut in the large rod? To bevel the edge. Quote
Members oldtimer Posted March 10, 2009 Members Report Posted March 10, 2009 (edited) CharlieR said: rgerbitz--did you happen to have a mchine drawing made of your cutter?Charlie What is the diameter of the cutter and how is the blade attached to it? What kind of blade do you use? Edited March 10, 2009 by oldtimer Quote "The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
Members CharlieR Posted March 10, 2009 Members Report Posted March 10, 2009 rgerbitz said: Sorry Charlie,The first model was one I made of wood. I took that to the machine shop and with a few modifications I had what you see there. If you would like some dimensions I could fix you up with something. Rob Rob--some basic dimensions would be great. By the way, what kind of splitter is that in the picutre? Charlie Quote
Members rgerbitz Posted March 10, 2009 Members Report Posted March 10, 2009 Charlie, The Diameter = 1.5 inches and the length = 5 inches. The angled cut is at 45 degrees. I am going to have another one made some day and when I do I will add another 3 inches on and put another angle at 30 degrees. It would also be nice if there were some kind of finger on the collar so that there wasn't so much surface area against the string when cutting. Old timer, I have been using the small utility knife blades, they are about an inch or so long. I use a black marker and put a mark along the cutting edge that wears off as I go. Easier to tell which part of the blade has been used, when the mark is all gone I throw that blade away. Hope this helps, Rob Quote http://gerbitzquarterhorses.com/
Members oldtimer Posted March 11, 2009 Members Report Posted March 11, 2009 (edited) rgerbitz said: Charlie,The Diameter = 1.5 inches and the length = 5 inches. The angled cut is at 45 degrees. I am going to have another one made some day and when I do I will add another 3 inches on and put another angle at 30 degrees. It would also be nice if there were some kind of finger on the collar so that there wasn't so much surface area against the string when cutting. Old timer, I have been using the small utility knife blades, they are about an inch or so long. I use a black marker and put a mark along the cutting edge that wears off as I go. Easier to tell which part of the blade has been used, when the mark is all gone I throw that blade away. Hope this helps, Rob One more question: Is there a indentation for the blade between the cylindrical pieces or is the blade just squeezed between the parts ? Thank´s ! / Knut Edited March 11, 2009 by oldtimer Quote "The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
Members rgerbitz Posted March 11, 2009 Members Report Posted March 11, 2009 It is just squeezed in there. Quote http://gerbitzquarterhorses.com/
Members megabit Posted March 16, 2009 Members Report Posted March 16, 2009 rgerbitz said: It is just squeezed in there. Thread hijack, Rob, I just clicked on you website link. Tampico IL, I grew up in East Moline and my Mom is from Walnut. Small world isn't it? I've been in SoCal for the last 30 years though. Mike Quote
Members rgerbitz Posted March 16, 2009 Members Report Posted March 16, 2009 I was born and raised in Walnut, who's your mom, maybe I know her. Rob Quote http://gerbitzquarterhorses.com/
Members megabit Posted March 16, 2009 Members Report Posted March 16, 2009 rgerbitz said: I was born and raised in Walnut, who's your mom, maybe I know her.Rob Wow now that is a small world. My Mom is Mary Lou Odel her parents were Mike and Fern. So if you know any Odel's or Wallaces from Walnut I am likely related to them. Quote
Members rgerbitz Posted March 17, 2009 Members Report Posted March 17, 2009 Real small world. It's not very often you find anyone who knows where the hell Walnut Il. is. Let alone someone who is a distant relation. My great grandmother is Anna Odel. Rob Quote http://gerbitzquarterhorses.com/
