hidepounder Posted April 22, 2009 Report Posted April 22, 2009 I do have a speed reducer & go ever so slow around the tip but still having problems driving.How far from the edge should I run my stitch groover? Right now I've got it set at 3/16". Should I try to get alittle closer to the edge? Also do most of you stitch groove the liner/back of the belt as well. I do....I feel it hides & protects the stitches from wear. I think 3/16" is a good distance. If you can get away with a stitch groove in the back, I think thats good. Looks better too. If you're having problems driving, is it because you can't tell where the needle is as you go around the curve? If so you might try grinding the nose off the needle presser foot. It made a lot of difference for me. Quote
