Members 41hammer Posted May 5, 2009 Members Report Posted May 5, 2009 hello and thanks for reading my post. i feel like i want to step up my game and make my belts look more professional and so i want to know what to use and how to seal what i use on the inside of my belts. i am not sure if with the new stains and dyes being water based if they will rub off on clothes over time. i was given the tip to seal them with scotch guard but in reading the bottle it says not for use on leather. also i would love a tip if i should use the same dyes as i would on the front on if there is a trick to get it as even as the front so it looks professional. thanks for your time tiffany Quote
Frank Posted May 5, 2009 Report Posted May 5, 2009 Tiffany, When it comes to dyeing items, I do use Fiebings oil dyes. I know a great many people do not like to use these on everyday items because they can rub off on clothing. I use Fiebings leather balm with atom wax after I dye the back side of belts. First dye the belt and let it dry thoroughly. Then apply a coat of the Fiebings leather balm with a foam brush. Let it dry for about 15-20 minutes. It dries very quickly. Apply a second coat on top of the first. Let it dry thoroughly and then buff with a piece of denim. That should keep any dye from rubbing off. So far I have not had a problem when I use this method. It's fairly easy and quick. I hope this helps out a bit. Frank Quote
Members 41hammer Posted May 5, 2009 Author Members Report Posted May 5, 2009 Tiffany,When it comes to dyeing items, I do use Fiebings oil dyes. I know a great many people do not like to use these on everyday items because they can rub off on clothing. I use Fiebings leather balm with atom wax after I dye the back side of belts. First dye the belt and let it dry thoroughly. Then apply a coat of the Fiebings leather balm with a foam brush. Let it dry for about 15-20 minutes. It dries very quickly. Apply a second coat on top of the first. Let it dry thoroughly and then buff with a piece of denim. That should keep any dye from rubbing off. So far I have not had a problem when I use this method. It's fairly easy and quick. I hope this helps out a bit. Frank thanks for your reply. however with being in california we no longer can get the fiebings dyes and the replacement stuff is water based. i was a huge fan of fiebings so it has been a hard switch. thanks for the info. i am going to see if anywhere might have any of the dye and leather balm left. tiffany Quote
Frank Posted May 5, 2009 Report Posted May 5, 2009 Tiffany, Maybe I wasn't as clear as I should have been. You can use the Fiebings leather balm with atom wax over the top of most dyes. I just prefer to use oil dye. Quote
