Well, I've learnt so much from this site but have a question that I'm hoping someone would be able to answer.
I've started experimenting with making Lanyards and have mastered using 2 colours of 1/8" Kangaroo Leather but how do I go about adding a third colour to a 4 part round braid? Do I have to cut 1 piece in 1/2 and then glue another piece to it?
I've used 3 different colours with a 6 part round braid which is very straightforward but not understanding how to add a 3rd colour in a 4 part round braid.
What do others recommend?
Also any tips on how to make the my first lead look a lot smoother as I've seen some where the leather just blends in together.
Thanks for everbody's help here.
P.S. Here is a pic of my first leash made.
Not sure I follow what you are asking. If I wanted 3 colors in a 4 plait braid I would use 2 strings of the same color and 2 strings of different colors like 2 white, 1 red and 1 blue. This of course means you can't attach your clip by doubling over 2 strings and would need to back braid at both ends. I guess you could splice in the 3rd color though if you didn't want to back braid for a loop.
I see where you are going with this...I know where to go with this now..duhhhh!!! LOL.... :You_Rock_Emoticon:
If ya want your braid to look smoother ya need to bevel your strings on the flesh side. And then roll the finished braid work between two boards with a little pressure.
Mike
Thanks Everybody...Rawhide and Megabit...would you be able to tell me what tool I would need to bevel the flesh side? That would be greatly appreciated as I would love my leash to have much more finished look to it. Thanks again.
Edited by animagusbc
Depends on how handy you are and what you want to spend. I know of at least one person who can do so free hand with a sharp knife. You can improvise a beveler with a hard board a nail and a knife. Or you could buy one. I like the one I got from WhiteBuf on here let me go find the link to the threads.
Here is a link: http://leatherworker.net/forum/index.php?showtopic=15534
Edited by megabit
Love it but just a tad bit expensive for me at the moment as I'm just a beginner and just learning the ropes here. The leash was my first project but I will see if I can get it cleaner looking by using the 2x4 to smooth it out.
What a great forum for learning...Shall I get into making masks too...I think my artsy fartsy side is coming out...LOL
I bought one of Whitebuff's string makers, too, and I love it. I'm totally new to braiding, and I was making my own nice looking strings about an hour after recieving it. This tool rocks.
You can take one of your strings and dye it from the mid-point. That means you might have to use natural color hide first and dye that string twice. Or you can dye a lighter string with darker dye. But a three-color 4 strand leash is gonna look a little awkward as far as color pattern goes. Migh be better off using three colors and a 6 strand leash.
As far as skiving the corners of the strands, it is important to get that part of the operation down solid or the finished project will not look finished. If you look at some of the whipmaking books, they show you how to do it by hand. The keys to hand skiving are make sure your blade is as sharp as you can get it. I use #11 scalpel blades and right out of the package, I give them a couple passes on the polishing wheel to give them that clean edge. Also you need to find a good cover for your finger. I make a collar out of 4-5 oz leather. Gives the laces a smooth surface to slide on, and also protects the finger when skiving.
Many whip makers skive the strands by hand because the strands taper and it's kinda hard to use a fixed width blade on the various cutters when the lace has to taper. Depending on the size of the whip, the strands could taper from 10-12 mm down to 3-4 mm at the point end. For a very fine finish, some will skive the flesh side with a deep cut say 45 deg. and then turn the lace over and just skive the tiniest corner off the hair side. When it is done right and rolled properly -(I use two pieces of marble slab), the resulting plaiting will feel like a snakeskin - textured with no sharp edges at all.
Just learn to walk backwards at a steady pace, have your strands soaped so they slide easy, keep your pulling hand steady and the blade hand firmly against the lace. It takes practice and I guarantee you will cut through a number of strands before you get it down.
Just my $.02 worth.
Jerry
