esantoro Posted June 30, 2009 Report Posted June 30, 2009 Does anyone know if it is possible to buy a small doming tool for use with small diameter (.085") solid rivets (to dome the post end), something about half the diameter of Tandy's doming tool. I can't use a solid rivet tool for #14 copper rivets (I already have one for #12 rivets) , because I need the doming tool to fit into tight spaces. Thanks, Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Moderator bruce johnson Posted June 30, 2009 Moderator Report Posted June 30, 2009 Ed, This is a tool you can make pretty easily yourself. Take some rod or a small bolt and grind it out with a dremel. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
esantoro Posted June 30, 2009 Author Report Posted June 30, 2009 bruce johnson said: Ed, This is a tool you can make pretty easily yourself. Take some rod or a small bolt and grind it out with a dremel. Thanks, Bruce. I'm on it tomorrow 7 a.m. ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
esantoro Posted June 30, 2009 Author Report Posted June 30, 2009 The hell with 7 am. That's only four hours away. Just found the right sized bolt. I'm on it now..................... Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Members CampbellRandall Posted June 30, 2009 Members Report Posted June 30, 2009 (edited) esantoro said: Does anyone know if it is possible to buy a small doming tool for use with small diameter (.085") solid rivets (to dome the post end), something about half the diameter of Tandy's doming tool. I can't use a solid rivet tool for #14 copper rivets (I already have one for #12 rivets) , because I need the doming tool to fit into tight spaces.Thanks, Ed http://www.campbell-bosworth.com/catalog/product_info.php/cPath/1_45/products_id/379' rel="external nofollow"> Edited June 30, 2009 by CampbellRandall Quote
esantoro Posted July 1, 2009 Author Report Posted July 1, 2009 I made the doming tool, but it seems a little light duty. There's something to be said for having a larger mass of hardened steel underneath the maul, but a narrow concave tip. Thanks, again, Bruce, for this suggestion. It was superb. ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
JoeS Posted March 31, 2010 Report Posted March 31, 2010 On 6/30/2009 at 4:58 AM, esantoro said: Does anyone know if it is possible to buy a small doming tool for use with small diameter (.085") solid rivets (to dome the post end), something about half the diameter of Tandy's doming tool. I can't use a solid rivet tool for #14 copper rivets (I already have one for #12 rivets) , because I need the doming tool to fit into tight spaces. Thanks, Ed Hi Ed, Old post I know, but I have a similar thing going, plus I'm new at this. First is, have you found a supplier you like for your #14s?. I'm finding my familiar places carry only the 9s and 12s. Also, I saw an old sheath that was nicely domed from a tool and set real nice so it wouldn't rub things that went by it. Is there a setup someone would be so kind as to recommend so mine don't look like my brother hit it with a 2 lb. brick hammer? thanks, spring is here, tomato seeds in, joe Quote www.jcsLeather.com
