ENGLISH_EUROPEAN SPANISH_GERMAN_FRENCH
leather_cuero_leder_cuir
embossing_gofrado, estampado_german?_french?
carved_...
pattern_...
tooling_...
You can to add more languages
Edited by Quijote
in french
those are the one i am sure
leather-->cuir
embossing-->embossage
carved-->graver (verb to carve) gravé (adj carved)
pattern-->patron
I am not sure but it looks good:
tooling--> outillié ou travaillé
I notice you specify European Spanish. I live in Peru, but as far as technical terms are concerned, I don't think there should be many, if any, differences. I'm trying to put together a course to teach to youngsters here in Peru, but many of the terms I'm not sure of how to translate. For instance:
case, casing (wetting the leather) = humedecer, humectación
tooling, carving = esculpir
stamping tools = herramientas de estampa
swivel knife = cuchillo giratorio
beveler = biselador
pear shader = ??? no tengo idea
mule foot = pezuña de mula
background tool = ???
camouflage = ???
veiner = ???
seeder = ???
leather punch = ojalador de cuero
modeling = modelar
burnish = bruñir
(leather)lace, lacing = lazo (de cuero), enlazar
If anyone can help me out with corrections and filling in the ones with ??? I would appreciate it. I'm sure I will find more as I get into the course.
Dale Erwin
Casa Erwin Custom Leather
http://leather.casaerwin.org
Thanks for your answers!
In french:
cuir builli = cuero "hervido", cuero endurecido
In spanish:
sewing = coser
pear shader = en forma de pera, ovalado
background tool = herramienta para difuminar el fondo
camouflage = camuflaje
veiner = ¿con forma de vena o de filón?, rallado
seeder = con forma de semilla, semillero
punch = sacabocados de diferentes formas (redondo, ovalado, corazón) y tamaños
modeling = modelar
tool (leather stamp) = troquel, mateador, punzón
pattern = plantilla, patrón o modelo (a copiar)
veg (vegetable) tanned leather = cuero de curtido vegetal
raw hide = cuero crudo
sheath = funda de cuero para cuchillo
holster = funda de cuero para pistola o revólver
scabbard = funda de cuero para espada
case = funda
leather box = caja de cuero
saddle = silla de montar a caballo
wax = cera
finished = acabado final
glue = pegamento
dye = tinte, teñir
sling = correa
belt = cinturón
purse = wallet = bolso o cartera
luggage = bolsos de viaje y maletas
bookbinding = encuadernación de libros
mask = máscara
quiver = carcaj, tubo de cuero para guardar flechas
mallet = mazo
eyelet = ojete
overstitch = marcador de espuela?
round knife = cuchillo de medialuna
incisado = to cut the leather with the swivel knife
modelado = modelling or molded?
repujado = embossing or carved?
gofrado = gophering?
Can you define the difference between embossing, gophering and carving? :helpsmilie:
I'm not sure what gophering is, but embossing is working the leather from the back with a ball-point modeling tool, pushing and stretching the leather so that the figure on the front actually rises above the level of the original surface of the leather, giving a 3-D effect. The lesson I read on it, says the first step, making no swivel-knife cuts, after tracing an outline of the figure (the example was a horse's head) to use a beveler around the outline which is visible from the back and then from the back use the modeling tool, inside the area where the figure will be, to push and stretch the leather until the desired height is achieved. Then he made a sort of a paste from leather-shavings (he called it leather dust) and rubber cement and filled the hole on the back to prevent the leather from returning to its original shape.
As you can tell, I've never actually done it myself.
Dale Erwin
One term I forgot:
How do you say "Leathercraft" in Spanish? I would guess "artesanía en cuero" ?
Dale Erwin
  casaerwin said:
One term I forgot:
Yes, is right, "Artesanía en cuero" or only "cuero". Leather = cuero; craft = afición, oficio, pasatiempo.
Spanish
Edge beveller = matacantos
casaerwin! Do you have pics of your course in spanish?
  Quijote said:
Spanish
I haven't finished it yet, but when I do, I can post it in pdf. It's going a lot slower than I thought it would. I would like to get your opinion of it. Even though you may find some of the language a bit different from the Spanish you are accustomed to. My wife is helping me, but she is not familiar with the terms.
You say edge beveler is matacantos, but what about a beveler stamp. I think that would be biselador, no?
I tend to forget about this board, so don't check it as often as I should. But you can contact me at
dale@casaerwin.org
Dale Erwin
How do you refer to different weights/thicknesses of leather in Spanish? In English, of course, we use ounces per square foot. I would have thought they would use grams per square meter, like paper, but when I found out that here in Peru leather is sold by the square foot (pie cuadrado), I began to doubt it. For instance, how would I say in Spanish "7-8 oz. tooling leather"?
Dale Erwin
