Members Nerd Posted August 19, 2009 Members Report Posted August 19, 2009 I am working on some leather wrist bands. Part of the wrist band is shown in the photo below. I need to glue a piece of square cotton canvas the same size as the leather square in the photo to the leather square. I've tried 3M super 77 and a Glue called Sew no more and neither work for very long. Any recommendations? Quote
Members Kustom Posted August 19, 2009 Members Report Posted August 19, 2009 None lo-voc contact cement should work. Have you tried that? Quote
Members Somawas Posted August 20, 2009 Members Report Posted August 20, 2009 Try rubber cement. I read an article that suggested rubber cementing leather to canvas, rather than cardboard, to keep it from stretching while tooling. The canvas does not tear off on the leather and can be reused. Quote
Members mulefool Posted August 20, 2009 Members Report Posted August 20, 2009 I do lots of work with leather on canvas (pack bags, half breeds for pack saddles) I've had really good luck with a product called Val A Tearmender. Apply to each piece, when it's tacky put them together. If it doesn't seem like it is adhering right at first I might tap with a French hammer to help it adhere. Chris Quote www.horseandmulegear.com
Members Nerd Posted August 20, 2009 Author Members Report Posted August 20, 2009 Try rubber cement. I read an article that suggested rubber cementing leather to canvas, rather than cardboard, to keep it from stretching while tooling. The canvas does not tear off on the leather and can be reused. Thanks. I'm not looking to reuse the canvas though. I'm looking for a super strong bond that can handle being flexed because the bands will be bent around the wrist and taken off. None lo-voc contact cement should work. Have you tried that? I have not tried that. Is None a brand name? What is Lo-voc? I do lots of work with leather on canvas (pack bags, half breeds for pack saddles) I've had really good luck with a product called Val A Tearmender. Apply to each piece, when it's tacky put them together. If it doesn't seem like it is adhering right at first I might tap with a French hammer to help it adhere. Chris Does this provide a super strong bond that can handle being flexed? I'm looking for something that you'd have a h#ll of a time pulling apart. Quote
Members Kustom Posted August 20, 2009 Members Report Posted August 20, 2009 Lo-voc is a watered down version they sell in California, it has low fumes and doesn't work as well. Just use Barge All Purpose Cement in the yellow and red can. Scuff up the leather with sandpaper where you want to put the cement if it needs it, put contact cement on both parts, let it set up them put the two pieces together. Quote
Members katsass Posted August 22, 2009 Members Report Posted August 22, 2009 Lo-voc is a watered down version they sell in California, it has low fumes and doesn't work as well. Just use Barge All Purpose Cement in the yellow and red can. Scuff up the leather with sandpaper where you want to put the cement if it needs it, put contact cement on both parts, let it set up them put the two pieces together. I agree with KUSTOM, Barge is great stuff, but if you can't find it without mail order (Tandy has it) you might try WELDWOOD contact cement. It's available at most home and garden supply places. (Don't get the gel formula) You can get it in 4oz bottles so you won't go broke getting a bottle to try. Just apply with the enclosed applicator and LET IT DRY - not tacky. Stick the two pieces together and roll it to make sure of contact (I use an old wallpaper seam roller) It should do the trick. Mike Quote NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!! At my age I find that I can live without sex..........but not without my glasses. Being old has an advantage.......nobody expects me to do anything in a hurry.
Members thecapgunkid Posted August 23, 2009 Members Report Posted August 23, 2009 I am working on some leather wrist bands. Part of the wrist band is shown in the photo below. I need to glue a piece of square cotton canvas the same size as the leather square in the photo to the leather square. I've tried 3M super 77 and a Glue called Sew no more and neither work for very long. Any recommendations? Quote
Members thecapgunkid Posted August 23, 2009 Members Report Posted August 23, 2009 I just signed on to this website, and not more than three hours before somebody asked me the same thing at one of our cowboy action shoots. In the past 30 years, I have been taught several things about mating canvas to leather. The first is, if it stinks, don't use it. If you gotta use contact or rubber cement, then post a fan at your back and blow all the fumes away from yourself whether or not the room is ventilated. Secondly, read the instructions on the adhesive you are using. There are a lot of retail/craft store products out there that'll do the job, but some of them will differentiate between a temporary bond where you gop up one side and slap them together real fast or whether you gop up both sides, wait until they get tacky and press them together. The third is that gluing cloth is not always the best thing to do because the less dense weaves will allow any glue to come through. Sometimes plain old retail glue sticks will workand sometimes, before stitching, even double sided tape will also work. The only times I have used the canvas/leather combination was when lining a hunting bag or saddle bags or a pair of shoes, and I used a medium gauge canvas in the process. I made a bouncer out of a steel rod and a ceramic doorknob, and will press the two halves together on a smooth marble slab to tighten the bond The last thing I was taught was to fold the edges of the canvas so that the stitches hold permanently. Right now I am using mostly Leather Factory/Tandy leatherweld or white glues, and relying on contact cement only when I need a really held fast bond before stitching, such as holster edges or welting/insole stitching on shoes. Hope this helps, and, Don't shoot yore eye out, kid The Capgun Kid Quote
Members jeeperaz Posted August 29, 2009 Members Report Posted August 29, 2009 The Capgun Kid... Welcome to the forum. Are you the same one who wrote an article on hand sewing leather on gunfighter.com? If so, it is one of the best tutorials I've read. Quote
Members thecapgunkid Posted August 30, 2009 Members Report Posted August 30, 2009 The Capgun Kid... Welcome to the forum. Are you the same one who wrote an article on hand sewing leather on gunfighter.com? If so, it is one of the best tutorials I've read. Yup, tha's the rumor. How is it you read the chronicle? What's yore alias? Thanks for the compliment Don't shoot yore eye out, kid Capgun Quote
Members olenawills Posted November 17, 2014 Members Report Posted November 17, 2014 (edited) Posted 30 August 2009 - 06:02 AM 'jeeperaz', on 29 Aug 2009 - 12:50 AM, said: The Capgun Kid... Welcome to the forum. Are you the same one who wrote an article on hand sewing leather on gunfighter.com? If so, it is one of the best tutorials I've read. Yup, tha's the rumor. How is it you read the chronicle? What's yore alias? Thanks for the compliment Hi, could you please add the link to this article or post it on this forum. I am very interested in one of the best tutorials Thank you. Edited November 17, 2014 by olenawills Quote
Members RoosterShooter Posted November 22, 2014 Members Report Posted November 22, 2014 (edited) Talking about 'Digging up the Dead'! This post was 6 YEARS OLD! I think that's a record. The last time 'Thecapgunkid' was active was sometime in 2012! Edited November 22, 2014 by RoosterShooter Quote
